Almonds, nuts, and pistachios
I just started eating lots of nuts with dried fruit… hmm I like it…
I see the back it says the nuts are fattening… I heard this is good fat? still, eating 20+ grams of fat cant be good right? Tell me…
Eat away… good healthy fats will not make you fat but processed carbs and sugars will.
Be adviced that these are VERY high density calories foods.
I’m totally addicted to Tamari flavoured almonds.
Less so with no salt pistachios.
Walnuts I eat coz they’re good for the heart, I think.
But, if you can get Tamari flavouerd almonds, you’ll never go back to plain.
This. Be cautious, especially if snacking when very hungry. It takes more to fill you up, and it’s easy to pack in a bunch of extra calories.
Example:
1 cup apricots - 75 calories.
1 cup dried apricots - 320 calories.
John
It really depends on which nuts you’re talking about. The primary fats in almonds for instance, are omega-6 fatty acids. Most of us already get way more of those than we need. Walnuts on the other hand have decent amounts of omega-3 fatty acids as do macadamias which have very little omgea-6 but a good deal of mono unsaturated fatty acids instead. IMHO the Almond Council has done a wonderful job convincing us how wonderfully healthy almonds are. I will admit to loving to eat them but do so in moderation. Walnuts go in my oatmeal every morning along with blue and black berries that I pick myself.
YMMV,
Hugh
Not to mention if you ate a cup of dried apricots you would be on the toilet for a dramatic movement. Ditto for a cup of almonds.
High fat diet = more efficient user of fat for energy = better endurance athlete (in most cases). Body still prefers CHO for workouts, but the higher percentage of fat you burn at higher intensity relative to carbohydrate, the better off you’ll be at events lasting longer than an hour or two.
EAT MORE NUTS!
+1 You also need to be wary of how the nuts are prepared. Obvious, but ‘raw’ nuts would be a better choice than those roasted in oil & salted (although they taste sooo good). After I broke my addiction to the smoked almonds, I actually like the raw ones better now. I taste the nut and not the oil.
You said, “I taste the nut.”
The green wasabi ones were what got me. When I went through almost an entire can in a few hours, I figured it was time to not buy them any more.
John
Same thoughts; I’d really limit the intake of prepared/coated/salted nuts. Raw or dry roasted, mixed with (refrigerated)oatmeal, yoghurt or salad, works for me. Tasty, good fat, filling combo. No massive calories, because you don’t eat that many grams of it when mixed.
YMMV,
Hugh
+1
i think walnuts have the highest omega-3/omega-6 ratio of any nuts. I basically get 20g of freshly-ground flax in the morning with 500mg of omega-3 fish oil, 200 kcal worth of walnuts in the day, and another 500mg of fish oil in the evening.
yes, almond and flax are calorically dense, but i truly believe that many of us buy too much into the whole “fat is bad” catchphrase. In any case, i find that the walnuts really help with satiety, not to mention that omega-3 is an essential fatty acid (i.e., your body can’t make it from glucose).
edit: apparently the ratio of omega-3/omega-6 in walnuts is only 0.24:1, and while this is indeed the highest for nuts (almonds has no omega 3), the ratio for flax is 4.5:1
Raw cashews > *
Roasted= BAD
Raw= Good
Dried Fruit= BAD
You like the dried fruit because it’s sweet and taste like cant. It’s about as healthy. Roasting nuts destroys their nutrition. The high heat just makes them almost empty calories. Sorry to rain on the parade. And Raw almonds, cashews, walnuts, and pecans are better then pistachios. Try that and get back to us on how you like to eat healthy nuts. :slight_smile: They are not nearly as tasty, way better for you.
Roasted= BAD
Raw= Good
Dried Fruit= BAD
what this guy said. most nuts are roasted in oil , where this oil is damaged into something toxic (polymerized fat, transfat, etc)
Fewer calories in almonds than are listed on the nutrition label
http://www.npr.org/blogs/thesalt/2012/08/03/158083010/if-almonds-bring-you-joy-enjoy-more-for-fewer-calories
Anyone else here soak and rinse their nuts prior to eating? I started doing that and it really cuts down own the tannin taste, but question whether it adds to the health benefits of raw nuts (better nutrient absorption, easier digestibility).
Plus the wife likes cleaner nuts…
John
Oh hell yes. These are straight from the devil!
http://pics2.ds-static.com/prodimg/191755/300.JPG
Be sure to soak your raw almonds. It breaks the skin down and you get more of the good stuff. Digestion is better.
Trader Joe’s has the small “Just a Handful” packages of raw almonds, I keep them in my desk at work when in need of a snack. I also have either raw walnuts or raw pecans with breakfast each morning.
