For those of you that don’t ride under UCI rules and are free to make whatever equipment choices you wish:
What handlebars and stem are you using on your bikes?
What bike are you using?
-SD
-SD
3T Ventus. ![]()
Zipp Vuka
Specialized Transition
I’d be happy trading that in for something more aero with 2 frame bottle mounts.
Syntace Stratos CX basebar - I have 3 of those, one on my Zipp 2001, one on my Kestrel KM-40, and one on my lady’s Felt B12. Her felt is the only UCI legal bike that I own. Softride has some other base bar on it now, but mostly I run it AOD.
Chris
-SD
One more variable–fork. I’m using a Blackwell Time Bandit (7:1 ratio).
The fork doesn’t concern me so much as I’ve already got a very very good UCI legal fork.
What are your bar/stem and frame choices?
Alum Vision Base bar and Aero bar
Ritchey adjustable stem and Bontrager Race stem
Cervelo P2 and Felt S32
jaretj
Hello Felt B12, with illegal Reynolds fork, highly modified Syntace blackbird aerobars, disk, H3.
All that said if money was no object I’d love to see a modern Lotus type design with inline stem and very narrow aerobars with a custom narrow rear disk with room for 5 or 6 cogs. Basically a flatcourse, few turns bike.
Styrrell
Hed blackdog drop bars.
Felt B2
Felt Alloy Bayonet handlebar
Look forward to seeing something UCI illegal.
3T Ventus on a P2C
I am curious what others have to say about a UCI illegal bike.
I would want three things before I purchased:
To fit the above things, it seems like Felt could simply keep their new version of the frame. But alter what comes with the frame, maybe a noseconed fork not just the bayonet, a draft box like attachment for the seatpost. Maybe a different basebar that comes with the bike, something like the new Bontrager one, about 15mm wide and 60mm deep.
I have VT alum base bar modified a bit with hed clip on with oval alum single bend extensions on a Cervelo P1. For the price its aero and inexpensive.
On a flat course, you’d be far better off taking off the derailleurs if you wanted aero savings. I used to run Willow both fixed and with gears. If it was windy, I’d use the bike that could shift, but I’d at about 28 minutes regardless of set up on a decent day. Even a hilly course like Hines was only about 30 seconds slower for me on the track bike.
I’d like to see a picture of your bike.
-SD
Felt B2
Ditto.
Virtually everything on my bike is UCI illegal…except the stem and bars:
Generic 1" 73 degree stem w/ Al Vision base bars and carbon Vision clip ons.
Titanflex frame (think the UCI would like this?)
Reynolds Ouzo Pro Aero Fork (older, ridiculously thin, high aspect ratio model)
80+ degree seat angle that runs afoul of UCI setback rule
Simkins Egg brakes (I don’t know if the UCI blesses these or not…)
Now all I’m looking for is one of these in-hub motors… ![]()
I’ll get you some later in the week. Nothing particularly special, but I did a lot of the work on the bars. I’m currently running one of the first gen Zipp cranks with one chainring, figuring they seem about as aero as you can get without spending big bucks. I had to really carve up a set of brakes so the rear brake does touch the chainring.
Styrrell
zipp 2001 frame
argos fork (>3 aspect ratio, super thin) 1" steerer
easton attack bars
bontrager stem
x2, on a Felt B2 2008.
The grubber assist bike used by Spartacus at Roubaix and the Ronde ![]()
