I watched the Science of Lance thing on Discovery the other day, and they did a bit on a mechanic who aged his tubulars in a cellar - for years! Apparently Lance will be riding tires in this tour that were made before he won his first one.
Is this just nuts or is there actually something to this?
All I know is it is a lie. A tublar made 6 or 7 years ago has got to be a half a gram heavier then one made today. As the Tufo posts prove that much wieght can cost you at least 6 or 7 miles an hour.
from the rec.bicycles.tech FAQ (which everyone should read):
What advantage is there in aging tubulars?
None! The aging concept arose from the same source as the “steel
frames need to be replaced because they get soft with age” concept.
Both were intended to improve sales during the off (winter) season by
bike shops with too much inventory on their shelves. Tires oxidize,
outgas, and polymerize from ultraviolet light. The concept of a tire
manufacturer making a tire that cannot be used until ripened for six
months from the date of purchase is ridiculous. Tires can be made to
any specification at the factory. Tires are most flexible and durable
when they are new. They don’t improve with time and exposure to heat,
light, and oxygen or ozone.
“Over-aged” tubular tires, have crumbling hard brown latex on their
sidewalls that exposes separating cords directly to weather and wear
and they have treads crack when flexed. Considering that this is a
continuous process, it is hard to explain where, in the time from
manufacture to the crumbly condition, the optimum age lies. The claim
that tires are lighter after aging is true. Their elastomers have
evaporated making the tire brittle and weak.
Purchasing tubular tires in advance to age them is unwise, although if
there is a supply problem, tubular tires bought in advance should be
sealed tightly in airtight bags and kept in the dark, optimally in a
freezer. For best results, use new tires because aged tires are only
as good as how little they have aged.
That means LA’s lead mechanic is full of dogie doo? He was shown on the show in his cellar with tons of aging tubulars all marked with the “born on” date, in large stacks, tied together. According his statement, Discovery will be using tubulars in this years TDF that were made 6-7 years ago.
So whats up? Why would he say something like that and show the world if it was not true? I really have no idea at all about this whole thing.
Did I misunderstood Discovery’s chief mechanic? I could have sworn he said he had aged those ‘tooboolurs’ (as pronounced by Devriese) as much as 6 years before allowing them to be glued on to race wheels? If that is what he said, I have a hard time believing it as I just do not see Lance (or any others from Disco) riding 6 year old tires even if it was stored in basement that rarely sees temps above 70 degrees!
A lot of people get wierd stuff in thier heads,Have you ever seen the photos of riders in early TDF smoking? The smoking Cleared the lungs! Maybe fifty years ago ageing tires had a purpose.
The other thing that happens to rubber is increasing cross-linking of the chain molecules, which I think is the main cause of stiffening/aging over time, since the molecules have less freedom to move. However, the predominant cause of this is sunlight/free radicals, which they’ll never see in a darkened cellar. There probably will be a few interstellar sub-atomic particles causing very small amounts of cross-linking, but I agree that this whole aging thing is baloney. Like you say, all these things can be controlled much better during manufacture anyway. That the Discovery team mechanic apparently believes in aging just shows the powers of tradition and superstition.
I was also supprised of some things said,Or left out There was talk of former champions of the TDF but no mention of Greg Lemond,i understand the bad blood between Greg and Lance but Lances life was made better by Greg being there before.
Argument from authority doesn’t cut it.
I was told by an old-timer that in years past when tires lacked the current rubber technology they would age their tires to harden the rubber and make them less prone to flats. BTW, he no longer ages his tires.
I can’t see how aging them would decrease rolling resistance. Seems as though older tubulars would lose grip as the rubber hardens.
Rolling resistance is the energy lost due to flexing of the tire (tread and casing) to conform to the road surface, not related to the tread/road interface.
Well I guess technically speaking, I age ‘tooboolurs’ since I do not train on my race wheels which means the race wheels are resting in the dual wheelbag aging. <:^D
You’re a grizzled old Belgian bike mechanic. A group of niave young Americans show up at your shop with video cameras and ask a bunch of stupid questions about Lance Armstrong.
You have a cellar full of left over tubulars from season’s past. What would you do in this situation?
The Discovery Channel probably left the shots they got of the tanks holding the “custom special air” on the cutting room floor to keep the show under one hour.
This segment also struck me as questionable in a show supposedly focused on science. IIR, the mechanic claimed that the glue used in making the tire became softer over time, leading to a more supple tire with lower rolling resistance. I really have no personal knowledge one way or the other as to whether this is true, but if rubber hardens with age, I would think this would increase rolling resistance, not decrease it, as it would make the tire stiffer.
But all this aside, why include this segment at all? If the show was supposed to be about the science of lance then there should have been some explanation of the chemical changes that lead to lower rolling resistance in aged tires. No such angle was taken, likely for obvious reasons–probably no such scientific knowledge exists. This and a number of other segments did demonstrate a very methodical and organized approach to the TDF. It may be a waste of time, but it is organized and methodical. Being organized and methodical is not the same as being scientific. Project management is not the same as science.
They had this same sgment on Fit TVs “Chasing Lance” series but I think Discovery edited the segment because when I saw it on Fit TV, at the point where Devriese was showing the stack tires for Lance, he made a comment to the effect that when that small stack of tires was done, so was Lance! (grin)
