The shape isn’t consistent as they taper to a narrower size about an inch or two away on either side from where the stem attaches.
I really like the handlebars, I was just hoping to put some aerobars on for some sprint tris.
I don’t want to change the whole set up as I do some longer road rides, so just curious as to what others have done if they found themself with the same situation, as there are a lot of Madone owners.
not because of the shape, but because the carbon isn’t reinforced at the point where clip-ons would normally go. I’ve seen a few guys try to put clipons on carbon bars that are not designed for clipons, and the results are not pretty.
if you want clipons, then swap the bar for an aluminium one, and you’ll be good.
