Aero helmet question (3)
Looking at buying more stuff I do not need. (Isn’t that the fun part?) Anyway, want to upgrade my wheels and get an aero helmet for race day. Thought I would shop for the cheaper option and grab an aero helmet first.
Looked at Giro first since that is the road bike helmet I have now and saw the Advantage 2. Then start reading about all kinds of problems people have with the ear flaps cracking on them. Since Giro is a major manufacturer I would assume if they are having this problem then most helmets have the same problem. But when I read online I really do not seem the same number of complaints for they other companies.
Is the Advantage 2 the only helmet that consistently has this problem? If so what helmet should I get? Really the only two I have ever rode with is Giro and Bell and Bell does not look like they have a TT helmet they sell in the U.S. So beyond those two I really have no idea what is a good helmet.
If most helmets have this problem I will probably just use my road helmet as is and put the money towards some wheels. But I have always heard dollar for dollar an aero helmet is a good buy for some “free” speed…so I thought I would give it a try.
Any other suggestions?
get the giro selector. it has a much sturdier construction and the variable tails and visor options make it extremely nice and very aero.
Advantage is a great helmet, just dont manhande it in transition…
You can F up the ear flaps on any aero helmet if you don’t treat it nicely. Whether or not the ear flaps on the Advantage 2 can crack with normal use is another question entirely, but in my experience as long as you treat your aero helmet well you can make it last you a long time. I’ve been using the same helmet since 06–it has dozens of races in it and nothing is cracked. I’ve kept it in a “hard shell” case for the last 3 years in between uses to prevent it from getting damaged during travel, etc.
Might want to invest in a case if there is one made for whatever helmet you end up getting…
x2.
I’ve had my Advantage II for 3 yrs and no problem with the flaps. I store it on a styrofoam head (mostly because it looks funny and drives my family crazy) and I make sure I don’t yank on the flaps when I’m pulling it on during a race.
It’s a non-issue.
Brad
Mine cracked at the ears but just a bit. Half a finger nail max…its not anything crazy. Like someone said above, if your hard on any aero helmet it will split.
try it on… the ear flaps on the Giro seemed tight for me to put the helmet on under stress so I went with the Louis Garneau Rocket. Lots of deals on Rocket/Rocket Air.
My first aero hat was a lg rocket and after a couple of years it craked in the shell next to the ears. I have had a specialised for the last year that came in a hard case. Transporting it in the hard case is key to a long life. Tim
Anyone use a hard case that fits their Giro Advantage 2. Recommend any? Thanks.
