Does anybody have any experience with an aero helmet in the winter?
I’ve been considering getting a ski helmet for winter cycling to stop my forehead from freezing, but an aero helmet might provide all the same benefits. (and is useful during the summer)
The main problem I have is as my head sweats, my forehead below my headband gets wet causing my brow to get really cold.
(I know it’s a bit early but the temperature just dropped 10 degrees here and it got me thinking about winter)
An idea…I made a winter riding helmet a few years back that I still use…started with a road helmet from Target or Walmart that covered more forehead than is covered by the more expensive brands. Added a few blocks of “fitting foam” leftover from some other helmet to the forehead area…lastly, I taped over the vents…It’s very warm. David K
I usually don’t wear anything under my helmet, just a headband over my forehead and ears. I think part of the problem is that I sweat a lot,even in the winter. My forehead is usually fine until my headband gets completely soaked. Different glasses or ski goggles might fix that though, I hadn’t really thought of that.
What brand is you helmet? If you have a Lazer chances are they have a rain cover / aero shell for it. It is a cover that snap on to the helmet. I have one for my Lazer O2 helmet.
Its not necessarily an aero helmet but nonetheless its what I use up here in Alaska Snow biking. Its the Giro Seam and it has served me well in 20 below. It is nice because it has an adjustable vent system that you can open or close to help regulate your temperature along with removable ear pads (muffs). Add a pair of goggles and balaclava and your all set. http://www.giro.com/us_en/seam.html?gclid=CIm2w5ntzrICFWHZQgod7AcAmQ
