Wanting to get an aero crankset for my SC 9 series. Is there a crankset compatible with Ultegra?
Sc9 uses a bb90 bottom bracket. So long as the aero crank you buy will fit a bb90/86.5, you should have no problems. Although I will put it out there that i’ve tried every crank available and I must say that Ultegra and Dura Ace are prob some of the most solid feeling cranks out there but the heart wants what the heart wants and what the heart wants is AERO. ![]()
Yeah, I would like something like the Campy Boro Ultra.
Damn! That is probably one of the only cranksets I’ve not gotten my hands on. I can see why you would want it!
From my understanding it uses the same bottom bracket/spindle as the ultra torque but may need BB adapters to work with bb86/92 frames. I haven’t done it personally so you may want to wait for someone who has done this to chime in… GOOD LUCK, that would be an awesome setup with an SC9
EDIT: Or maybe Carl can chime in and help you out. Knows everything about Treks ![]()
Also forgot to mention you might have a problem running a Campy chain on shimano components.
How about this?
No Shimano aside from older 105. He’s all SRAM.
No problem with 11 speed. And in this case - use all current shimaNo stuff, except the crankset.
Should be GTG with the Bora crankset and SC9.
Wowzers… nicest sc out there
What Groupo are you running with that?
I suspect that is not Dave’s bike, look at his signature.
Yeah, just wish someone knew for sure if that crank was compatible with Ultegra 11 speed.
The bike isn’t mine. It’s one of the Trek pros with a Campy sponsorship. That’s SR EPS.
-Dave
I’ve used the Campy Bullet crankset with Shimano 11 speed with no problems whatsoever. Actually a friend is using this crankset on their road bike at the moment. The Bullet is a similar shape/design lower-grade Athena/Chorus carbon crankset but has a smaller inner chainring option. The Bora is 39t inner or bigger.
-SD
