I just got a felt ia 2.0 and I cant figure out how to adjust the angle of the seat. It is slightly tilted up and I want it slightly tilted down. I have owned many bikes over the years and have never encountered this problem…
Yeah, that one is tricky. You have to remove the saddle to access the two grooved/ribbed/fluted barrels. Then you need to rotate the barrels to get the saddle tilt you are seeking. The larger of the two makes something of a “macro” adjustment and the smaller, inside barrel makes a micro adjustment. I recall that i would “clock” the larger barrel in the direction i wanted the nose of the saddle to go (it becomes a surprizingly large agjustment) and turn the inner barrel the opposite direction to then minimize the adjust. Go into this with a great deal of patience as it takes several tweaks to get it right.
Ian
It uses the 3T Difflock system. Here’s a vid showing how to adjust.
