Hi guys, I’m looking for a 90mm adjustable stem that goes down to -45deg 31.8mm clamp 1-1/8 steerer
Either that or does anyone make a ±40-50deg stem in the above dimensions?
thanks in advance
thanks in advance
Ritchey makes one, but only in an 80 or 100 length. Sell for $45 or so, I use one.
Unfortunately I need something like 87mm, as the reach gets a bit messed up as you go lower … an 80mm at -45deg turns out to be like 70mm in effective reach.
Oval makes one in 95mm … maybe I won’t notice the difference. It looks like some no-name companies make them in 90mm, but I’m a bit leery of them. Last thing I want is for the stem to slip, near 100% chance of crashing if that happens
I got a Kalloy Adjustable that goes to 60deg from Jensen USA but in 26.0mm. You could check there.
