Hi,
I’m new here and would appreciate some advice from anyone who has a perspective on trying to be an active person after getting a ruptured ACL.
I was training in jiu jitsu - standing up and a nutbag wrapped my knee with his leg, held it tightly between his knees so I had no ability to rotate my knee and then scooped / shoved me sideways over my trapped knee. I fell but my knee didn’t follow.
Now My ACL is completely severed and I have a fractured tibia at the back near the top and some bone bruising on the femur. Apparently when the knee dislocated that far the femur can come out and whack the back of your tibia and because the femur is the strongest bone in the body the tibia looses out.
So it will be more than 12 months post op before I can go back to BJJ - if I decide I still want to. However, I’m swimming now with a pool buoy and I’m told I should be able to run again after about 6 months - with or without surgery. I imagine I’ll be able to cycle before I can run. I’ve joined a swimming club and I’m interested in joining a triathlon club later when I can do more.
Does anyone here have experience RE training after rupturing an ACL? Any advice / wisdom to share? I’ve done some ultr marathons before so if I end up getting into triathlons instead of going back to BJJ I think I’ll be drawn to the longer events.
Hi,
Thanks,
Sharla
Had mine repaired in 1991, and I rode 13000kms last year.
I’m tipping the surgery & recovery has come a long way since then!
Indoor riding will be safe & I’d start hitting the bike as soon as you get the all clear.
One thing…err on the side of caution, running wise - and be guided by the medicos…particularly with anything involving a change of direction.
My knowledge of this injury is limited to college basketball. One of our top players tore his ACL midway through the year & the timeline to play again (on a minutes restriction) is ~8 months. Full minutes 10-12 months. It’s one of those where it really takes a year to rebuild & get back up to normal training load/volume.
In 1997 I had reconstructive surgery from a wrestling injury. I was given the 6-12 month timeline for full recovery. I also tore the meniscus pad which concerned the surgeon because they can sew it up but it often only partial heals leaving spot that are not attached that cause pop in the knee. There was a girl in two of my high school class who also had ACL surgery by same doctor on the same day as me. We had our first rehab session at the same time and I was not able to get a full revolution on the stationary bike and she was. She was getting the rehab done and I was whining because it hurt too much and was too hard. So I committed to do 100% of the therapy that was assigned from there on no matter how hard it was or how much it hurt. At 5 months I was released to go back to 100% activity with no limits. I was shocked. Best case senecio was 6 months and average was 8-9 months. The keys for me was that my mom has a stationary bike that I could use every day. That really hurt but got my mobility back. I also had a weight machine that I could use every day after I was released to do weights at 3 months. That also helped a ton. In the first months it was a lot of leg lifts then medicine bands. It was slow going and some days it took 75 minutes to do all those leg lifts that were prescribed. I all of wrestling practice on week days to get through my PT though so I stuck to it and got it done. I didn’t think I ever would be able to do triathlons. My knee was good for about 5 years then it became apparent that it was weak. I couldn’t sit in a car for 30 minutes without my knee acting up because I had to stretch it all the way out or it would go numb or get that asleep limb tingle. I was a runner and could run without limitations in straight lines but corners gave me that weak knee feeling and side to side pivoting was a no go. My younger brother did two full Ironman races in 2002 and since we did everything together growing up I wanted to know what a triathlon was like (just not a full Ironman). It wasn’t until 2014 that I decided to see if I could do a triathlon. The first fews in the water the knee felt weird. I could feel it wobble with any type of whip kick. Straight lines like I did in running seam bearable though. The knee also felt weak on the bike and after a 15-20 mile ride was sore. I was causing any damage though so I kept at it and after two month I was able to sit in a car for 30-minutes with out the knee acting up for the first time in over a decade. The wobble in the knee went away in the water, the knee no longer limited me on the bike (although my bike position is non conventional to take some of the pressure of the knee and alway my to straighten the leg out at the bottom of the stroke if needed). I can now run corners with no knee weakness and can ever do side to side pivots. So, for me triathlon has done wonders for my knee. Follow your PT 100%. Don’t do anything before the doctors and physical therapists release you to do it, and use you bike, weights, and swimming to strengthen that knee and get its full mobility back. Hard work goes a long way.
I’m not a doctor but I’ve had two ACL repairs - same knee, about 10 years apart.
Swimming with a torn ACL is fine but breaststroke or eggbeater kick may give you problems. Once you have it repaired, you’ll need some time out of the pool. But you’ll be focused on PT and rehab. Do what they say and make sure you get your range of motion and strength back. Part of that PT will be on a stationary bike - which is one of the safest things you can do. The docs will let you know when you can get back to running or lifting.
If they let you start lifting, be very careful with quad and over-the-knee weight. Leg press laying on your back is ok, but avoid squats and leg extensions for awhile.
I imagine triathlon would be possible without repairing your ACL but I didn’t like the feeling of instability and it would have impacted other things I like to do. Obviously it’s your choice, but docs are very good at this surgery nowadays.
13000 kms is a decent effort! Good to hear you don’t seem to be limited by it! I will keep that in mind when I get to running. I’ll have to hold off on playing too many enthusiastic games of chasie with my daughter!
I’ve already had to get a 3rd opinion because my Sports med Dr and Physio did not agree on how long I should be using crutches for my fracture. I went to discuss it with a surgeon and it turns out the fracture was at the back of the shin bone - not on the top - as my femur hit it when my knee dislocated. So I was going to be on crutches for 6 weeks before going to my next phase of treatment / rehab but now I know I don’t have to be. I thought I had to keep all my weight off of my leg but I just have to use the crutches to NOT fall over. In just 2 weeks of using crutches I lost close to 50% of my left quad muscle and now I need to build it back up. I shudder to think about how shrivelled my leg would’ve been after 6 weeks!
Luckily I do have a Wahoo Kickr so I’ll put that to use! So far I think I agree with you in terms of the lack of stability without getting the ACL repaired. It is just the weirdest feeling! I’d like to feel like I can run again one day without stacking it as soon as I find myself feeling fatigued on uneven ground.
Thank you for sharing your story. There are so many depressing stories out there RE how long it takes to recover etc. Your story gives me some hope! Did you ever go back to wrestling?
How are you measuring the 50%? Just curious.
If the crutches are just to prevent falls, would a cane work too? Might be easier on your shoulders, or you could mix and match. Or even trekking poles?
Keep us updated. I’m glad you don’t have to be non weight bearing for 6 weeks!
Good luck with the recovery. Be guided by the consultant and physio and don’t compare yourself to anyone else.
Look at the recovery as a training challenge rather than rehab. And alway look on the positive aspects. You may be stiff or sore one day but that is still better than last week or month.
Pre-operatively get as active as you can as early as your consultant and physio allow you to be. To go into surgery with as much range of movement and strength as possible will facilitate a better result overall.
Without a functioning ACL (and without other damage or the stump catching in the wrong spot) you can still walk, jog, run, sprint and hop on one leg in a straight line. Just cannot rotate through it.
Stationary bike can be as early as 3 weeks as it’s straight line. Pool exercises are encouraged once the wounds are fully healed but avoid breast stroke kick.
Graft is at it’s weakest and most vulnerable at around 2 months so no inadvertent twisting. For every month beyond the graft will increase in tensile strength but will be 6 months before it can withstand a moderate strain, and is still only around 70% of it’s eventual strength.
Some people may allow running as early as 3 months but they are really taking a chance in my opinion. I wouldn’t be jogging on it until after 5 months to give it the best chance of not getting an accidental strain. Month 3-6 can be spent on general fitness, strengthening and lots of learning how to land, with bouncing hopping and skipping.
Return to full level sport involving rotation is generally accepted to be anywhere between 8-12 months. Back years ago there were so-called ‘accelerated protocols’ which claimed to get people back at 6 months but due to re-rupture rates and the 2-3 month graft weakest point most people have moved away from these as it’s not worth the risk.
Again, best of luck and listen to your Consultant and physio.
And get your knee straight as early as possible. That’s the key to the entire recovery.
I had the ACL Surgery my Junior year of High School. yes, I was able to wrestle part of my senior year.
Wrestling wasn’t good to me though. I had season ending injuries my Sophomore (knee), Junior (Knee, ACL), and Senior year (separated Elbow). I went undefeated my 9th grade year at the junior high level. I thought I was a lot better wrestler than I was a runner, but if I had to do it all over again I would have been better off just focusing on running.
I promised my mom after I separated my elbow that I would never wrestle again. I walked on to the University Cross Country and Long Distance Track team, but after missing my junior year of running from knee surgery and half of my senior year from wrestling injuries too I didn’t get any scholarship offers. I was the sophomore regional champion in the 1600m but ended up as the only guy on our varsity cross country team who did have a running recruitment offer. I just did the redshirt freshman walk on thing one year. I didn’t earn a scholarship so I just focused on studies after my freshman year and didn’t run for the university.
One year my mom saw that there was a intermural wrestling tournament at my university and she excitedly asked me if I was going to participate in it. After all the worry I put her through every time I wrestled I was sure that she would be telling my to not even dare to break my promise and wrestle. She didn’t have to though. She told me it was okay if I wanted to do the intermural wrestling tournament but I didn’t break my promise. I haven’t wrestled.
I did get to wrestle in few duals meets and tournaments my Senior year, but the ACL injury was in all practicality the end of my wrestling career. I never finished a season after that, never got to go to the state meet, etc.
Thanks Mart!
At the moment I’m just walking as even that feels a bit weird after being on crutches for 2 weeks. I wonder if I can stationary bike before the surgery safely?
I’ve been swimming - just using my upper body and a pool buoy to keep my legs afloat.
It feels a little weird if I don’t take the turns at the end of the pool super slowly but otherwise it seems ok.
I expect my surgery to be scheduled in a few weeks.
I see a trend in everyone’s responses - Sounds like I need to make friends with the bike!
I ruptured my ACL about 20 years ago but it wasn’t correctly diagnosed at the time, and was only discovered in an MRI earlier this year. Over the past 20 years I’ve played soccer, tennis, squash, kitesurfing, snowboarding and Ironman. With sufficient rehab it is definitely possible to function entirely normally without an ACL!
I have a friend without an ACL who wrestles but she’s an Olympian so her physical conditioning is likely to be better than what I can realistically achieve as a mum with a full time job. She says there are some things she can’t do - she can’t come up onto her toes and pivot at the same time. Her wrestling style had to be adapted to deal with not having an ACL. So no kickboxing etc.
My concern RE not getting it fixed is also the idea that my knee will be more prone to arthritis etc. However, I would have expected your knee to complain a bit more than usual doing long distance races such as the Ironman.
What was the MRI on your knee for? Is it possible that whatever injury / pain you have had the MRI for is a consequence of the ruptured ACL?
I’m also concerned about being an elderly lady one day and being more prone to accidents leading to a broken hip as my muscles weaken. I’d prefer to go quietly in my sleep very late in life than to suffer after breaking a hip. I know that’s a very specific example - a friend’s mother died that way last year and I gather it was a painful way to go!
I haven’t had an ACL in my left knee and damaged menisci for the better part of 20 years as well. ARMY Dr’s told me not to worry about it.
I had one occasion playing football where it gave out but since I’ve enjoyed moderate amounts of Basketball and as much Triathlon related sports as possible.
I do avoid serious trail running because the fear is in the back of my mind.
I think you’ll be just fine. Listen to the Physio here during the acute phase and you’'ll be back before you know it.
