A hole in my 2XU suit
Hey all.
I’ve discovered a hole in my 2XU suit, unfortunately. This is strange since my suit is new(bought it a few months ago from an ebay seller, although it was new, unused). I take care of the suit like it was made of glass, taking care not to harm it. Hang it on a wide hanger and not in the sun.
Will it grow if not fixed? How bad is it for performance? Thanks :)Anyway, I’ve included some pics. Should I fix it somehow? WIll it grow if not fixed? How bad is it for performance? Thanks :slight_smile:
http://imageshack.us/g/1/9922960/
http://imageshack.us/photo/my-images/22/img8770copy.jpg/
http://imageshack.us/photo/my-images/407/img8769copy.jpg/
http://imageshack.us/photo/my-images/233/img8768copy.jpg/
Hey all.
That looks like a fingernail gouge, very common on wetsuits. I would suggest buying some black neoprene wetsuit glue and doing a quick repair job. As far as performance I wouldn’t worry about it, but if you are then use the glue and fix it.
http://imageshack.us/a/img22/8606/img8770copy.jpg
http://img407.imageshack.us/img407/7017/img8769copy.jpg
http://imageshack.us/a/img233/4496/img8768copy.jpg
Hey, thanks for the reply.
Is there a chance the hole might grow if I do not glue it? that’s one of my main concerns…(planning on fixing it but need to purchase glue first dont know how long that will take)
Quite common! i would just fix it quickly with glue.
superglue
thanks guys :slight_smile:
If you can find some Aquaseal, it’s perfect to fix these types of holes.
https://shop.sunrisecyclery.com/item/38694?gclid=CIG8qoWNorQCFelDMgoduyAAtg
i use this stuff, seems to hold up pretty good.
what i do is lay the wetsuit to the rip is on a flat surface (like you’ve done for the pictures) then take some masking tape and tape a rectangle around it with maybe 1/8" to 1/4" margin all the way around (if that makes any sense)
then brush the wetsuit glue all over it and get it down into the tear, let it set up a little and then take the masking tape off. i think it makes it look a little cleaner than having a brush stroke of glue all over the place.
I will respectfully disagree with this method and recommend to not use a lot of glue, and/ or put glue anywhere but inside the tear.
In fact, Profile Design doesn’t recommend it that way either.
http://www.profile-design.com/files/profile-design/pdfs/wetsuit-tips/wetsuit_repair_tips.pdf
Not to be matter of fact, just to be sure that you get the best repair that you can. I think that any wetsuit repair glue should work. Aqua Seal and the Profile Design stuff work very well.
I agree with the recommendation to only apply glue on the inside of the tear. This will help to keep the tear from growing.
Here is a good video on how to do it:
http://www.youtube.com/watch?v=plpv2GYgJnw
If you apply the glue on the surface of the wetsuit, the chances that it will tear further, especially in an area of stretching and movement grows significantly. When the glue hardens it generally isn’t very soft or flexible. When you stretch that material, it will pull on whatever it is holding on to. The inside of the suit will hold this bond better than the silicone coated surface.
I’ve seen a lot of repair jobs with too much glue used on the outside of the tear, that resulted in further tearing due to the glue pulling off of the outside of the suit.
If the tear is all the way through, you will need to apply a patch, I would recommend putting the patch on the inside only and use glue to repair the outside.
To answer the OP’s question, yes it will tear more if you don’t fix it. Maybe not the first time you use it, but it will eventually. I’d recommend you try to repair that before using it again.
Especially with tears on the seam, it is important to repair these, to prolong the life and performance of your wetsuit.
Will a tear affect the performance of the suit? A surface tear? Not to a noticeable degree. Though, if the tear is all the way through, it will start to allow water into the suit. This will start to diminish performance characteristics.
Good luck.
jake
hmmm. wish i’da seen this a while ago…
oh well life goes on.
Your method isn’t wrong. And in some parts of the suit that are thicker and don’t stretch much, it could work just fine.
I think the consensus on these repairs, by the industry will be pretty steady though.
And if it’s working for you, I wouldn’t knock it.
jake
thanks Jake for a very complete answer
