If it does not get cancelled, get some plastic trashbags and put then under your jersey on the bike. Wear disposable garden gloves and a rain vest if you can get one. Two pairs of socks if needed.
I’d carry one trashbag on the run just in case it starts pouring - you can always fashion it into a jacket and run in it. It will keep you warm.
Rain jacket on bike would be like pulling a parachute. Put some of those ironman plastic bags under you singlet, bike with swim cap underneath helmet, and gloves. I also like to tape my bike shoes vents shut with duct tape…that really helps!
You can do like big Matty Reed and race in wetsuit but I think that was a sprint tri!!!
I thought of this too I think it was Boise 70.3 and quite a few pros did it
IM Louisville 2018 (43° and rainy) taught me that, as obvious as it sounds, it’s better to be wet and warm than wet and cold. My experience is that the water usually finds its way in, so all I can do is work on the warmth. A tight base layer (UnderArmour) worked wonders for me, essentially functioning as a wetsuit on the bike. I didn’t personally use a rain jacket over top, but it strikes me as a good idea. Gloves are a must for me, & boot covers can be helpful too.
Only other tip would be to know and address where cold hits you most. My fingers go numb before I even feel cold elsewhere, so I packed a hand warmer so I would stand a fighting chance at changing a flat.
This was at Calgary 70.3, but the bike was considerably shortened.
