54cm Cervelo Renaissance Only 100 ever made
Steel Cervelo 54cm Italian made at Columbus - $4000
Production limited to 100 becuase of High dollar labor and material cost.
Frame-54cm 2002 limited edition(only 100 in the entire world) Cervelo Reniassance. The material used is a unique Columbus Thermcrom. The tubes were shaped, butted, drawn specifcally for Cervelo. The material was drawn into the form that Phil and Gerard designed to be as light and efficient as steel can possibly be. The welding was left to the finest makers of steel at Columbus tubing in Italy. This is the only Cervelo made in Italy. The welding process used was brazed sillet brass which ends up being lighter than a tig weld because the joining material(sillet brass) is lighter. If you are a Cervelo steel fan then you are probably wondering how this frame is different from the super prodigy? The entire rear tri-angle is thermacrom on the Renaissance unlike the super prodigy. The chain stays are a different more wide oval tapered to round on the Renaissance. This provides more lateral stiffness. The Renaissance is not nickel plated. The super prodigy was tig welded. Renaissance is significantly lighter. Frame or bike has never been ridden in the rain never wrecked and is 99% like new. There are a couple of hair line scratches that would not show up in a picture. Two small nicks. The paint is of course worn around the rear dropout where the rear wheel clamps down. 54cm top tube, 53.5cm bb center to top of top tube. You can view this bike in the discontinued models section of cervelos web site: http://www.cervelo.com/content.aspx?m=About&i=DiscontinuedModels#6 I manage Austin Tri-cyclist. One of the top five cervelo dealers in the country. This is the only steel bike in the store everyone will miss it. The bicycle is amazingly smooth. I can not empasize that enough. It is very responsive and is worthy of any great race.
Fork-Columbus Muscle 1" full carbon with Titanium mesh damping
Warranty- This bicycle was purchased from Cervelo in 2004 after they initiated a lifetime warranty on all bicycles sold post 2003. I will include a receipt from the bicycle shop for you to use in the unlikely event of a problem with the frame.
All parts listed below are brand new/never ridden
Shimano DuraAce STI
Front Derailleur Shimano DuraAce
Rear Derailleur Shimano DuraAce
Cassette Shimano Ultegra 12-25
Chain Shimano Ultegra
Brake Calipers Shimano DuraAce
Crankset FSA SLK MegaExo
Bottom Bracket FSA SLK MegaExo
Stem FSA OS-150
Handlebars FSA RD-250
Saddle Selle Italia SLR Gel Flow
Wheels Easton Circuit
Tires Vittoria Diamante Pro Lite
Call Brad with Questions 512-507-9485
Price $4000 Firm for 3 weeks
How much does it weigh?
Complete bike without pedals weighs in just under 17.25lbs
Thanks for you insterest
