53/39 with 12/25 versus 52/38 and 11/25
After reading all the compact etc. stuff it got me looking at my gearing and chain length.
Currently running the standard 53/39 with a 12/25 and have run a 12/27 in the past.
Very hilly where I live but don’t grind too bad with a 39/25 and don’t like the spacing of a 12/27 cassette.
I looked at using a 52/38 with an 11/25 and it seems it would give me a slightly easier gear for climbing than a 39/25 but at the same time give me a bigger gear for the downhill with the 52/11 versus a 53/12.
Do they make 52 and 38 combinations for Shimano 10 speed?
Do they make a 11/25 cassette.
Does any of this make sense!
Yes, the question makes sense, and all cyclists should ask it. What is the best gearing for me?
The change from 53/39 with 12/25 to 52/38 with 11/25 would have the following effect: Big increase in your big gear: 53/12 to 52/11 takes your GI from 119.2 to 127.6. This is the major change, you get a much bigger top gear. Small impact on your little gear as you go from 39/25 to 38/25 and change from 42.1 to 41 gear inches. I looked at the Shiman web site, and there does not appear to be a 38 front chainring for either Dura Ace or Ultegra, and they do not make an 11-25 cassette.
How about this suggestion? Change to a compact crank with a setup for 50/34 chainrings and 11-23 cassette. Compared to your 53/39 with 12/25, here is what you will acheive / gain: Moderate increase in your big gear: 53/12 to 50/11 takes your GI from 119.2 to 122.7. So, you still get a bigger gear than you had, which seemed to be one of your goals. Moderately easier lower gear for climbing: 39/25 to 34/23 takes your GI from 42.1 to 39.9, and gives you a little more to spin up hills with. Better gear spacing, which is narrower and not as “jumpy” as the 12/27 that you don’t like.
So, with a compact, you can acheive your goals. If you can climb with a 39/25, then you’ll climb even better with a 34/23, and you’ll have a larger big gear as well. You improve on both ends, and you never need to change your setup (swapping out to 12/25 or 12/27) unless you want to climb steep and long, then you can put on one of the other cassettes if you want that extra “anesthesia” gear.
Hope that helps.
I have used a 52 on the front for years. Reason - it allows me to make better use of those middle gears on the cassette and keep it in the big ring longer. I run a 39 inner ring and use a 12-25 cassette in the back. Unless it’s a monster, long and steep climb I can usually I am fine with the 39/25 as my smallest gear.
38T and 52T chainrings that will work with 10s Shimano cranksets are available from FSA. I don’t think FSA chainrings shift quite as smoothly as Shimano, but they are good enough.
Thanks, well explained! I’ll have to run some GI for the compact setup versus a 39-25 or 39-27.
Bigger gear is less a goal on the downhill - I can still hit 50mph on the hill by my home! That’s enough!
FSA makes a 38 compatible with shimano. Had no problems using it.
*So, with a compact, you can acheive your goals. If you can climb with a 39/25, then you’ll climb even better with a 34/23, and you’ll have a larger big gear as well. *
I used a compact and while it was awesome on the hills I positively hated it on the flats. Most of my riding is done at speeds around 28-33 kmh (17-21 mph) and the 50-34 combo results in huge shifts in that speed range.
Francois in Montreal
http://www.panix.com/~jbarrm/cycal/cycal.30f.html
I purchased a Shimano compatible 38 inner ring from Nashbar a year or so ago for a cross bike. DavidK
sram makes a shimano 10 compatible 11-26 cassette, not sure if there’s an 11-25 out there.
yes, sram also makes an 11-25 with this combo…11,12,13,14,15,17,19,21,23,25
Thanks, they say it’s doesn’t work with D/A 7800 hubs. I run 10 spd but I don’t think my hubs are D/A - Mavic Kysrium wheels. Don’t know what hub body they have.
That 11-26 SRAM or 12-26 might be the ticket. The SRAM has only a 3 jump on the last cog (21/23/26) and the Shimano has two 3T jumps (21/24/27) and no 3T jumps on a 12-25.
The SRAM 11-26 just drops out the 16. Interesting.
