I recently discovered the Strava training log which gives yearly hours. I’ve struggled the last few years handling training volume and haven’t come even close to 500 hours. I’m on track for around 400 total this year, and had under 430 last year(and felt like I spent most of the year crushed).
I have the time and organizational structure to get significantly more hours in, and I have a very long history of endurance training in cycling (though still, nothing over 500 hours in the last decade+), but once I get a few 9-11 hour weeks in, the fatigue is absolutely crushing, and I have to take a few days off/a 3-4 hour week.
I’ve got a sub 4:50 HIM and a 97+ USAT ranking for Olympics and sprints, so I feel like my training is effective-ish, but I’m definitely plateaued fitness-wise, and it’s becoming increasingly frustrating having to back off every time I temporarily bump volume due to soul-crushing fatigue.
I don’t do too much intensity (very little intensity on the bike, 1-2 hard swims (2500 yards at a time) a week, and one run with 3-6k of 10k- threshold pace a week). But even just dropping the one run workout doesn’t make a difference in fatigue.
Is it a matter of filling in the extra time with very, very easy riding and running? Strictly z1 stuff? I’ve always eschewed that in the past since it seemed to have so little return and rested instead, but I’m not sure how to get in more volume at this point. Just trying to add z2 hasn’t worked so far as even that felt too hard (especially in summer with egregious heat/humidity).
Firstly I have to ask, what is so special about doing 500 hours a year?
You said any time you bump the volume you get massive fatigue. So that tells me you don’t need to, and shouldn’t be doing more volume.
And your comment about not doing much intensity.
I suspect you would be better off keeping the same, or reducing the volume, and increasing the intensity to improve your speed.
Doing more, potentially junk, miles probably won’t help.
I would get over the aim to do 500 hours a year and focus your efforts where you will b get the most gains. I suspect doing more intensity work might be it.
500 is more than I’ve been doing and what I’ve been doing has not led to additional progression. To be competitive in my age group requires being in the realm of a 4:20-4:30 HIM, but by the 4 hour mark I’m toast.
Sure, I can drop down to 7-8 hours and do more intensity (and have done that in the past), but it doesn’t help in longer races.
You didn’t mention if you’re on a plan or not. It def helps with the volume increases to be on a long-term plan, even if it’s a canned one, in that it’ll manage the volume increases at a reasonable level to build the volume. If you’re already on a plan, then you might have to find a different one with a different approach and/or ramp.
It sounds like you do your easy too hard. It’s almost impossible to go too easy, easy to go too hard. I’m pretty close to 500 hours for the year already and IMO it’s been kind of a down year for me, hoping to take some time off and come in strong to rebuild into next year. My rule of thumb though is that when I’m too tired relative to how I think I should feel given other factors in the week, it’s always because I was doing my easy too hard.
We’ve created this space where we consider z1/low z2 miles as “junk miles”. IMO these are some of the most important miles I do when training for endurance events, as someone who primarily bike races. IMO for most amateur athletes, the high z2/low z3 miles are the real junk miles because the demands of the rest of your life prevent you from recovering well from those, and the additional gain is very small when compared to easier training. Also, if you have the space in your life to support it, occasional 20+ hour training weeks are incredibly effective, even though they’re typically going to be primarily easy riding.
“I don’t do too much intensity (very little intensity on the bike, 1-2 hard swims (2500 yards at a time) a week, and one run with 3-6k of 10k- threshold pace a week)…once I get a few 9-11 hour weeks in, the fatigue is absolutely crushing, and I have to take a few days off/a 3-4 hour week.”
Something doesn’t add up. Either your “easy” sessions are too hard or there is something off with your recovery (sleep, stress, nutrition). If you are following a reasonable intensity distribution, are ramping up volume gradually, and recovery is decent 9-11 hours shouldn’t be crushing you.
While I agree with others that there is nothing special about 500 hours, there is definitely a correlation between training volume and performance. So I understand why you want to solve this issue.
Nothing new to add over some others, but just wanted to throw more weight on the correct answers here - go easier on your easy workouts, make sure you get enough sleep, and eat well. Going from 8 hours/week to 10-11 hours/week should be no problem if you do the above.
What is your 10k run pace and what pace are your easy runs?
How many hours of sleep do you get per night?
How old are you? 500 hpy is on the order of 1.5 hpd if you workout 6 dpw and take no weeks off. Based on my own schedule - unobtainable. With a couple of weeks off and a couple of weeks off due to injury/overuse, you are getting close to two hpd of workouts. Are you a professional, without other work obligations? Maybe OK. For virtually everyone else - more than feasible.
Had the exact same issue when i trained when not ill or injured and ramped up hitting the 10h/week would maKe me feel like i am about to be sick any minute.
I was young stress free life so no idea why, i can only think of too much intensity/bad genetics 😆
Are you saying its doable or not-doable? You said both.
10 hours a week, is not that much. Many Pros train twice that.
As a working engineer for the last 30 years, I’ve done more than 10 hours per week / 500 hours per year most of my adult life. All the tips have been noted above. Slow down, sleep, eat. Get a trainer, and a treadmill…so you can train when its not good outside (dark, cold, raining).
I follow someone who has done 1k hours per year the last few years. Elite masters runner and skier in his 50s, no kids and YT for work and online coaching. But does easy work at 100-110 hr on the elliptical and easy walking and lunging on the treadmill. High 15s 5k level runner and won many many us masters championships in different things
Interesting stuff, and it may be the key new thing to try.
I’m the opposite coming from bike racing. I never did a single z1 ride and raced super successfully (for me, at least) on winters of 2-4 sweetspot to threshold rides a week with a smattering of vo2 work near race season.
I basically dialed in my training to such an extent (and living outside of a city helps) that every single ride had less than 10% of total time below z2 , striving for maximum time efficiency.
Possibly this is the mindset I need to work away from.
I’m around 6:20/mile for 10k pace, 8:05-8:20 for 20-60 minute easy runs, and sometimes a bit faster for a long run, maybe 60-90 minutes at 7:30-8:00 every other week or so.
I’m in bed at 8:00-8:15 and up at 4:00-4:15 without fail. Average about 7:15 to 7:30 hours of restful sleep according to the sleep tracker. I never use an alarm clock and typically wake up wide awake even if still physically tired. I’ve tried sleeping more but even on rest days I just lay there awake if I don’t get up. May be a bit of anxiety involved, but it seems I’m losing 5-10 minutes of restful sleep ability every couple of years, if that makes any sense. I’m a few months from 40 years old.
I have started addressing nutrition to a much closer extent these last few months (trying to control another variable) and use Dr. Harrison’s Saturday app on nearly every workout, consuming calories on almost everything above 45 minutes. I was worried at first I’d gain weight but now I don’t overeat nearly as much afterwards and feel much better in general throughout the day. I have begun consuming significantly more protein over the last year or so, and I do think that has helped.
The more I read and reflect, the more it sounds like it’s coming down to z2/easy rides and runs being a bit too hard.
I’ve tried a personal coach (a bit more consistent volume weeks in the 8-10 hour range; I was wrecked by the 8th week and had to stop) and an 80/20 70.3 plan in the past, along with the more traditional progressive 3 weeks up, 1 week down plans that I’d use as a base template and modify.
But to your point, I recently set up a Phil Mosely Master’s 70.3 plan for next season that rotates a 2 bigger week/1 shorter week setup rather than the typical 3/1 or consistent volume weeks
Sorry, stupid Fire tablet likes to aggressively autocorrect - I catch most, but not all. I’m saying that, for most folks who are not pros, 500 hpy is very difficult to achieve. Sure, if this is your only hobby, or you have minimal family obligations, or any number of circumstances that free up time relative to most folks, then 500 hpy could be in the cards. I also pointed out that, if you’re a pro and training is part of your job, sure, 500 hpy - and more - is achievable. For me - job, family with two children, an aging parent and aging parents-in-law nearby, etc. - 500 hpy is unobtanium. And I think that that is true for most - but as you point out and are an example of - not all.
500h/y=20h/w (call it a 2 week offseason). It’s not that much. If you have a demanding job and young kids, impossible. If you have an ordinary office job and no kids it’s almost too easy. Wake up early, find a pool near your commute, keep your spouse happy.
M - AM 1.5h Bike PM 1h swim
T - AM 1h Run PM 1h bike
W - AM 2h Bike PM 1h swim
T - AM 1h run PM 1h bike
F - AM 1h Bike PM 1h swim
S - 5h bike
S - 2h bike + 1.5h run
**500h/y=20h/w **(call it a 2 week offseason). It’s not that much. If you have a demanding job and young kids, impossible. If you have an ordinary office job and no kids it’s almost too easy. Wake up early, find a pool near your commute, keep your spouse happy.
S - 5h bike
Math - You are going too fast and making simple math errors, buddy. 500 hr/yr = 10 hr/wk.
