[quote Tri or DieThanks to both of you…ok, this now sounds like cheaper fix. where I live is dead-pancake-flat. we do have consistent wind so when we get infront of a tail wind, the speeds were higher then I was ready for (95% of my riding is solo). I am new to the nervous-bunch-pack-cycling though I have been racing triathlon for 15 years. my 2 biggest problems was catching the last wheel after my rotation and suddenly have to accelerate when people were attacking or coming out of corners. I would go for a “click” and I was maxed out and missing the wheel all while spinning over 130-135 rpm’s. I felt like I was dropped because I am not used to the accelerations and my bike is NOT set up for me. I have since been fitted, but I didn’t spend time with my purchase like I did on my TT bike.
Soooo, you guys think I should just swap out some cogs? These new ultegra compact cranks…can I swap out the big chain ring?
Are you sure about that? 50x12 at 130 rpm is 43mph…
“Back in the day”, I used to do NRC races and never used anything smaller than a 39x23. If at all possible I’d use an 12x19 or 12x21 to keep the spacing close with 7 or 8 speed cassette’s. Now I’m older and of course, not quite as strong. But not by much. I can still make the front group over the climb of a local race with D3 pro’s in it, it just involves a LOT more groveling than it used to. Now I ride a compact, 50x36 and if it’s hilly a 12x27 cassette. The fact that I CAN make it up a climb in a certain gear does NOT mean that I SHOULD. Frankly, I think that if I had access to a compact “back in the day”, that I would have done better in some races than I did back then. Mashing a big gear was never my strong point and on steep hills I had a harder time that I would have with a smaller gear. Assuming that my young ego would have let me try it…
As for the flats, a 50x12 is a slightly bigger gear than Eddy Merckx used. 53x13 was the norm back then. I rode a 40km TT in 50:11 and never used anything bigger than 50x12. In fact, the only situation where that gear has been an issue is on one course that has a section with a perfect combination of a strong tail wind and downhill, but not steep enough to tuck. We hit speeds of around 45-50 mph and it was hard. Spin like mad, tuck in, repeat.
What I’m getting at is that a short burst of 120-125 rpm should be no big deal. If it is, then the problem is not the mechanical gears, but the legs pushing those gears. Granted, being able to spin at 120 rpm isn’t generally relevant to performing well in a triathlon, but it is to road racing and criteriums or groups rides. Gearing up might help some, but I suspect that the problem has more to do with a lack of acceleration than pure speed. If they are opening a big gap out of the corner you will have to hit a higher top speed than the pack to close the gap. With better acceleration you can follow the group and end up with a slightly lower top speed. The further back you are, the worse it gets. BTW, you can generally accelerate better in a smaller gear. Think about how fast your car is off the line in 5th gear…
In a 50x12:
90 rpm is 29.7 mph
100 rpm is 33 mph
110 rpm is 36 mph
120 rpm is 39.6 mph
Okay, show of hands. Who finds themselves at the front going 30mph for extended periods of time and wishes that they could go even faster?
BTW, one piece of advice if you have two different setups. Go with the 54 on the TT bike as the gear ratios on a 54 line up fairly well with the 50 for the small half of the cassette… i.e. 54x14 is pretty close to 50x13, so you’ll find yourself with fairly similar gears on the two bikes, just slightly more top or bottom end depending on which bike.
