IT was late last year or earlier this year that the 4x4 was discussed, along with what one of the Nordics called High-Low training. And my apologies for not getting the name of the ST author of this piece, but it is a great piece that I used as a base for my Kona training this year and I certainly think it makes good sense.
"I can try to give some insight in this kind of training since I grew up in it as a cross country skier in Norway. So first of all, this is nothing new, and the use of lactate and HR monitor started in the beginning of the 80. The interesting thing is that the HR monitor was mostly used to keep intensity down and sometimes we had to walk uphill to keep it low enough (you will find a lot of long hills in Norway).
Also training under this system is based on time, not speed. You will go and run/ski/roller ski for 90 minutes. Nowhere in your training plan will a coach talk to you about your speed. You as an athlete need to find out what is easy and stay there. One good sign, if people stop talking during an easy workout the intensity is too high. Yes, an easy workout is talking speed and yes you have to scale back in the hills (that is hard for cyclists).
During intervals individual start is quite common, you should not push too hard in the beginning and then die, but keep the whole workout at the correct level (do not go into read). For the top level skiers, using lactate is quite common to make sure they are not pushing too hard or too low during intervals (hard is usually most common, but low if the athlete is tired or close to overtraining).
How to set up a program with this methodology.
If you work out every day, you can have 5 easy days and 2 hard. If you work out more, keep 2 hard sessions and just add easy. For adults, intervals should be around 30 minutes (4x8,5x6, 6x5). The reference to 4x4 in the video is actually a reference to a debate in Norway about intensity, intervals and if you need easy training. If 2 hard sessions seams hard, start with one.
You will find it frustrating to go slow so maybe turn off your GPS and Strata
During intervals, make sure the first one is the slowest, do not start too hard.
Let me know if you have any other questions.
And yes, I got in hell of a shape using this (sadly many of my competitors did the same
foobarx, I can’t ever imagine my body sustaining 4X4 daily for 10 days, but then again, I’m a slightly older MOP, has been who never was.
so what is the difference in 4x4 to 5x4 or 3x6 etc? seems like stressors to me,and stress is what an interval is all about isn’t it?
