Does anyone know when it will be available?
Will it come in the -17 degree flavor?
Will it come with the old Ventus comfort cradles and pads?
3T just put up their 2012 catalog with the Ventus 2 in it.
Why would they only have a +6 degree available? Same with the older Vetnus LTD. Isn’t the aero benefit coming from -17 degree and having the base bar level with the top tube?
probably not enough market for people that get super low =)
there is always the USE tula, use any stem you want
Even with the -17 on a “regular” tt bike, the basebar still sits higher than the top tube… I do agree though the -17 is probably the best option as you have quite a bit of vertical adjustability with their spacer kits.
May be a mute point at this juncture, but 3T says -17.5 degrees.
http://www.3tcycling.com/products.aspx?p=Ventus
Yeah, saw that this week when they revamped their catalog. Very sexy!!!
