Hi,
somebody know will be the 3T Brezza II fit with Sync parts
https://www.syncergonomics.com/shop
or with the parts from
special the
https://www.aero-coach.co.uk/store/product/aerocoach-angled-spacers-for-arm-rests
Thanks
Hi,
special the
Thanks
The Sync Wedges and the Aerocoach wedges you linked to will tilt the PAD only. The extension/mounting hardware will not tilt with them.
Aerocoach does sell tilt block adapters that tilt the entire assembly (mounting hardware, bars, and pads together)
This is the link for that. You need to tell them what bar it is for. (Aura/Ventus should be the same hardware as the Brezza2)
Thanks for the request
When I understand it right the
https://www.aero-coach.co.uk/store/product/aerocoach-tilt-block-adapter-for-aerobars
will move the extension up and the
will move the arm cups up
I only the the arm cups move
Will it fit from aerocoach ?
yes
1st link - moves everything together
2nd link - only the arm cups
thanks for the help
Will be this combination fit ?
Basebar: 3T Brezza II
Extension: https://www.aero-coach.co.uk/store/product/aerocoach-angles-aerobar-extensions / Aerococh
Angled Spacer Arm Cups: https://www.aero-coach.co.uk/store/product/aerocoach-angled-spacers-for-arm-rests / Aerocoach
Arm Cups: https://www.syncergonomics.com/shop/deep-groove-arm-cups / Sync
Thanks
Yep, That should all work ok
