3t aura vs zipp vuka clip
They both seem pretty adjustable from a stack stand point. Does anyone have any opinions in which is better
They are both adjustable from the stack perspective, but the Zipp gives you a lot more flexibility with the width between the extensions and fore/aft positioning of the arm pads. With the Zipp, you can also put the extensions below the bar. It’s pretty hard to beat the Zipp when it comes to the adjustability.
I was between the two as well. I have to stack my left side 35-45mm because of a bone-length issue. I’m going with the Zipp and got the Bontrager carbon extensions with the wrist relief. I, too, like the adjustability options that the Zipp offers, as I seem to be changing my positioning more frequently in my 40’s with flexibility/comfort issues that come with aging.
you can purchase a riser kit for the aura bars: 10, 20, (30), 60mm.
If you want to check and make sure the Vuka Alumina Clip does offer enough adjustment to accommodate your fit, try out our Vuka Fit tool: http://www.zipp.com/support/vukafit/index.php
You can also download it from the iTunes store.
