I have a 2012 Cervelo P3 Tri-bike, and am looking for 60mm 3T Aura-Pro Risers. Any suggestions as to where I can find them? Thanks.
Wow, I also have a 2012 P3 and would love to find the risers, too.
I am told these are compatible, but I’m hesitant to pull the trigger and purchase without verification from someone more experienced than I. None of this would be a problem if I were as flexible as I used to be!
https://www.speedmetrics.com.br/us/products/straight-spacers/
They were as rare as Hen’s teeth 2 years ago, and I’m sure the situation hasn’t improved. Fibre-lyte make compatible spacers from carbon fibre though- which I think you should be able to stack up, perhaps with a cross brace at the top for stability. https://www.fibre-lyte.co.uk/...ycles_timetrial.html. Their standard is 6mm, but I imagine they will do a 10mm if you ask.
Thank you, Tim. I sent them an email this morning making an inquiry as to whether they are custom-making 60 mm risers and whether they recommend a cross-brace. Sure appreciate your referral. Thanks.
No problem. I doubt if they’ll do 60mm, as they’ll cut the risers from a CF sheet, but they should able to supply multiple 10mm ones.
I had the same issue and found that the Red Shift spacers from amazon work great. You’ll have to buy some longer m5 bolts from the local hardware store but that’s it.
