$40 shipped…NEW
$30 used for one month…
I have two available.
3T designs the ARX Team stem to be stiff, durable and light -in that order. The stem isn’t the lightest stem you’ll find; however, it is a great balance of all three features.
Using a similar 3D forging method Deda uses on their ultra light weight Deda Zero100 Servizio Corse stem 3T added more material to the design - resulting in a heavier stem. This additional material helps in keeping the stem stiff on the hardest sprints. More material equals greater durability.
Passing the CEN standards as well as a series of internal testing, the 3T ARX Team stem is likely one of the better all rounded aluminum stems currently available. 3T ensures compatibility with other major manufactures through their R&D process so you won’t ruin a bar or steerer tube when installed correctly.
The clamp uses 4 titanium bolts to help save some weight on its 31.7mm clamp. The front clamp will fit 31.7 and 31.8mm bars. The 3T ARX Team stem has a stack height of 40mm.
3T ARX Team Stem Details
Material: Aluminum
Clamp: 31.8
Angle: +/- 6 degrees
Stack Height: 40mm
Length: 110mm
Steerer: 1 1/8”
