Has anyone put 32mm tires on standard 700c Shimano RS wheels? In theory I think should work and have enough frame clearance but thought would see if anyone has put into practice. Thanks
32mm tire on a 15mm inner width rim works fine, you just can’t reduce pressure as much as with a wider 19mm rim, and you get a bit more of a light bulb shape. Frame clearance will depend on your bike.
