2XU Trisuit Sizing
Does anyone know how the 2XU one-piece trisuits fit height wise? I’m looking at a medium in my chest and waist measurements, but I am 6’3".
I tried contacting them directly, but they have not responded.
Cheers,
I was in the same boat but 6’2 (32" waist, 175lbs), and I went with a large and it fits great. Hope this helps
Thanks! I race at ~172 so I think I will do the same.
Don’t know but here are some good prices
http://www.theclymb.com/brand-event/3419/2XU
Do NOT go by their sizing though
I’m 6’2" - 6’3" and ~155lb and have a 2XU one-piece that’s M and fits fine.
How tight is that on you? Do you think it would work for someone racing at 170? I may be able to be 165 this season, but that is a stretch.
Thanks for the help
I’m just over 6’1 and 170 and use a large but needed it for swimmers shoulders, the M was way too tight across the chest. it’s not as tight as i’d like on waist but not uncomfortable loose.
Snug but not restricting at all, it doesn’t pull on my shoulders and I believe it has a lot of room to give in the horizontal direction.
Hi SwimRunTri, would you share your chest and waist measurement? I am tossing up between the L and M and am your height and weight…
I am 5’11 and have a M. I couldn’t see someone 6’3 fitting into it. Just my opinion. It seems way too short.
Seems the 2xu run on the small side. I’m about 5’7" or 8 and weigh around 153 right now and have worn small in other brands but this one is tight in the chest. I may opt for a Med this year.
I’m about 32in waist and 42-43 chest. altho feeling a little bigger than a 32 at the moment!
Im 6’2" 175lbs and tried both med and large. Large fitted better and was easier to get in to. However i had a problem with the collar. Both of the were scraching my neck.
Large it is, thanks guys.
Thanks! I ended up going with the large, which seems to be the consensus. I won’t know till it gets in though.
