Technical Bike Question : Has anyone successfully use 700x25mm tries on a 2015 Specialized Shiv Pro Race? The wheel set I’m using is the Roval Rapid 60CL (clincher). I’ve used 24mm Specialized tires - no problem. But, my new 25mm Continental 4000IIs seem to jam into the rear bottom break bracket (Magura). Wondering if I can adjust the break set-up (?). Or is the Specialized Shiv just not built for 25 mm tires ?
I’ve been running conti gp4000 IIs 25mm for two seasons on my s-works shiv. No issues ever, with the Tektro (?) calipers. Could be differences in brand’s tire measurements though.
Appreciate ST insights. Thanks.
You could always look to some wider rims with a larger internal diameter if you really have problems. I am GUESSING the fit would easier with the Roval CLX 64s which have a 21mm ID.
