anything out there/available?
yes I know its a “race” bike —> but want to raise up base bar height.
steer tube is 1" - can use shim with standard 1 1/8" clamp
top tube cap has additional hole for brake line – can make custom cap to be compatible
steer tube above bearing only 30 mm-- standard stem clamp high of 42mm ish
any suggestions - option?
for the Sworks TT version - want to change stock basebar/stem—> What basebar/stem upragdes are available? I need to raise basebar higher. thanks advance
