2021 Cervelo P-series
2021 P-series changed colors and now is equipped with Zipp Vuka Bull Carbon bar/Zipp Vukashift AXS90 extensions even in the Ultegra Di2 spec, according to the Cervelo site. Any views about this new cockpit?
It’s quite nice
Thanks. I like these news colorways minus the Vision front hydration much better.
here’s a picture of the two new colorways “in person.” both are quite good
https://posts.gle/uDqCr
ETA - google’s business listings can be a bit clunky; instagram might be better
https://www.instagram.com/p/CDcNSajh162/
If they bring that blue to the P5d I’m going to have a serious urge to upgrade my 2020 P5d frame already :expressionless:
The color scheme is exactly the same as my 2014 NP3.
not sure which color scheme you are referring to
This one?
Vs https://www.theproscloset.com/products/cervelo-p3-ultegra-58cm-bike-2015
it’s not the same at all, but i did actually like that older scheme as well.
#smallvictories
That’s a typo in the specs. The vuka shift axs extensions cannot be used with Di2 and are not spec’d on the Di2 bike, as you can also see in the picture.
Jeroen
Thanks, Jeroen. That was my guess as well. What are those extensions?
Those are regular zipp evo 110, from the looks the carbon version. To be hones that is my biggest gripe on that bike because the 110’s need the pads to be tilted as well but that is not default possible.
Jeroen
That dark blue is really nice!
Jeroen
Thanks. I assume those are regular diameter and can be replaced with another set of extensions (Zipp or non-Zipp) if needed?
The greenish blue one is gorgeous
https://lh3.googleusercontent.com/p/AF1QipOVs_7jRVxwaErxEGueBXGlg1AL2eEry9vBTJ0o=w608-h608-p-no
Totally agree! Bought my P2 two years ago. Would have chosen this color in a heartbeat.
Yes, standard 22.2 mm
Hello Jeroen,
We launched a new pad angle kit for the Vuka Clip Earlier this year. It is part 11.6618.030.000 HANDLEBAR VUKA CLIP B1 HIGH MOUNT ANGLE WEDGE KIT (5, 10 AND 15 DEGREE AND BOLTS). Your SRAM local distributor should be able to get it for you.
Best
Nathan Schickel
Zipp Product manager
P5 now coming with the tilt ^^^^^
