I just purchased an used Woodway 4Front. Is there a way to get into the settings menu? I assume you can see total mileage and tweak any settings there? I can not find any reference to it in the manual. I have the personal trainer display.
I am also reading contradicting posts on the Zwift forum that older models can natively transmit BLE. I know you can connect a GEM Retro to the CSAFE port, but does it have any native BLE?
Are you able to update software in anyway? I am not sure if Woodway releasing anything like that for their standard, non prosmart models.
Waiting for a new dedicated circuit run to test her out.
When you turn it on press the plus and minus at the same time for elevation. I should say holding the plus and minus, hit the green “on” button. You should then be able to scroll through the hours and miles. Beware hours and miles are broken out between two LEDs, so if your unit has 5432 miles it will read 5 in one screen, then 432 in the numbers furthest to the right.
Mine has ANT for HRM, but I dont think it broadcasts to other devices, it just receives my HR strap. My console is the personal trainer console, and mine is a 2018.
I would get a dedicated 20 AMP circut as they indicate.
