2016 Cannondale slice size chart help
Hi guys,
Is anybody can let me know what size will fit someone 5/6 male and 28 inseam?
The website does not show any  height size recommendation.
I was think 48cm or 51cm.
Thank you,
Not sure if this is helpful but, Im 5’10" with a 29inch inseam and I’m on a 60. That was following a bike fit, way bigger than I thought I would be on
You should get a bike fit… If you cant afford one, then you probably can’t afford that bike ^^; I would probably rule out the 48 though.
Got a pic of you on your bike? With the caveat that height and inseam are only two measures in a bike fit, albeit important measures…
Not saying your fitter did you a disservice but at 5’10" with a short inseam I’d be willing to bet your fitter did you a disservice, and probably by a factor of two bike sizes. You’d naturally be long and low given your height and inseam, which Cannondales are naturally not. On a 60 with a 29" inseam I find it hard to believe you could stand over the top tube or that your seat post isn’t slammed as low as it can go. You’ll notice that 60 is the largest bike that Cannondale makes, and you’re an 1" above the average height of an American male. Something doesn’t add up.
WOW, I am also about 5’10", long legs witha shorter torso and ride a 54 2016 Slice.
That sounds like you got sold the bike that was in stock and they had to get rid of.
After those replies I had to go and check… I was convinced I was on a 60… turns out I’m on a 57.
Definitley not, they had all sizes in stock and I didn’t really make my buying decision until after my fit, I cant remember what fitting system it was, but they basically get you on a rig, adjust it based on feedback, power measurements in position, my thoughts etc and it spits out a list of suitable bikes. Slice won on spec, and price but in reality i could have walked out with any of 4 or 5 bikes.
Still sounds too big.
Post a video of you riding and someone will give you a thorough critique.
Agreed. A 57 is way better than 60 but more than likely still too big. He’s a 54, and probably not even debatable.
I actually ride a slice, and they do run small. I’m 6’ with a 30" inseam, and the 57 is just about too small for me.
I agree with the advice here that you should get a bike fit; smaller folks like us have issues with getting bikes that are the right size and I’ve been left wondering several times whether I’m riding too big of a bike. Having said all that, I’m 5"7 and also have a 28 inseam, and I recently got fit onto a 51 slice. I found it necessary to slam the stem which requires removing the plastic piece that the cables go through and getting a new headset dust cap cover that I had to order from some website in the UK.
Hi guys,
Thank you,
I’m 5’7/28 and am a 51cm. No way a 48cm for you?
I’m basically your size and ride a 51. I think I’d like to get the front lower too, but I’m still working on strength and flexibility in the neck and shoulders.
I’m 73.5 inches tall and would ride a 2016 57cm Slice. My 2010 Slice is a 58cm and I fit around a 54.5 frame stack.
wow, i am 6’1 with a 34" inseam and ride a 57
I’m 5’3" with 30-31" inseam, on a 48 frame.
I’m 5’8" and on a 54. Got fit by the man himself.
I’m a stocky-ish 5’7 plus a little guy with shorter legs than typical. Seat height here is 69.5cm center to top, but on 155s. Was 68.5 on 165s. BTW, I love the shorter cranks for fit. Wasn’t cheap, was worth it. I guess if I wasn’t older and thicker it might matter less.
http://i64.tinypic.com/2aflb7k.jpg
This is a 51, and it’s a tad short in cockpit length with a 100 stem on it. Edit I did write 51 for you, but then I remembered that I had to pull all the stops, or almost all of them, to get my pad height in the right ballpark (low enough). So how about try this: use the diamondback andean pad X/Y calculator and show us what it says. We might be able to be more ballpark helpful from there. Mine was close…
Matt
I’m 6’ and ride a 57.
