does anyone know if its likely the e118 will be replaced for 2015?
Thinking of getting a e118 but will wait if there’s gonna be a new model, not sure how often Argon replace models.
Last time I talked to my bike mechanic he mentioned a couple new bikes coming from Argon 18 but a new TT/triathlon bike was not in the mix. Last rumour I heard was there was a gravel bike and an aero road bike coming out from Argon 18 in 2015 so I would guess that the E-118 will remain mostly the same.
bummer - cheers… will stick to the 114 and the gallium pro, both still great bikes.
I wish Argon would go for a tri-specific/non UCI E118 ala the Shiv. The tubes on the E118 do look a little skiiny. Solid ride though really happy with my Argon duo (E80/E118)
I was thinking of checking one out next week (a Shiv) - to perhaps build a new commuter bike.
defo agreed re. the tri-specific/non UCI - could only be even faster…
agreed…surprised all the major bike companies haven’t followed Specialized…why is everyone so slow to join the market? Triathlons have never been more popular!
As far as I know there will be a facelift for the e-118.
- New basebar without sharp angles.
- Stiff cockpit with new integrated headset (oneness 3.0)
- No need to cut extensions. More standard solution.
- Integrated front brake cable (finally!!!)
- Adapter for integrated Di2 BTR2 battery in the seatpost.
Worth lookig at before buying the old 2012-2014 version.
I was looking at replacing my front fork on my 2012 E-118 due to crashes, but they don’t have any with the correct paint any longer … so I’m going toward a more permanent solution with a local carbon repair shop.
With that said … talking with the Argon 18 rep, it sounds the the front fork is getting a full face lift, but the main frame will basically be the same. I’m guessing a different stem that is replaceable, new base bar and maybe different brake location or design.
The rep also stated he didn’t think the new fork would work with older model E-118’s … which kinda sucks as it would be a way to improve on an otherwise great bike.
Can someone confirm Wookiebikers statement? That the fork for E118 NEXT, yes thats the name of the new frame, wont fit the E118 2012-2014 frame.
