I was wondering what size my Ritchey Pro stem is that came on my Cervelo P3? Does anyone know what size stems come stock on these bikes? The frame size is a 55 cm if that matters.
Not to be a total wise ass, but why not measure it?
Their web site is ritcheylogic.com.
It is harder to measure than you would think. I just went through this with my 2003 P2k. Measuring from one side I would call it 100mm, from the other side it came out to 90mm. I finally decided that it was a 100mm stem, 17* rise. I wouldn’t be surprised if yours was the same.
This is the one I bought to replace my 100mm stem, it is heavy, ugly and cheap. Also, it sits higher than the Ritchey so I had to take out one riser to keep the bars at the same height. I’ve never ordered from this site before but everything came as promised.
http://aebike.com/site/page.cfm?PageID=30&SKU=SM1971
1-1/8" Threadless Road Stems, 73/107 Degree
Dimension
Dimension 26.0 90mm 73/107°Blk1-1/8" stem (SM1971)
$20.99
Mine came with the Syntace F99 stem, I thought that was the stock item. Can’t you switch it one for one at your LBS (supplier) or did you order it privately?
