Does anyone know if their is a brand that sells longer then 120 mm tubeless valves, more like 140 mm as my rims are already 120 mm high.
Or, of they exist but i couldn’t find them, extenders for tubeless valves?
Thanks,
Jeroen
Thanks,
Jeroen
Any reason you couldn’t use standard extenders with removable cores?
What rims are you running?
For tubeless they need to have thread on them to fix the nut to the rim which the extenders don’t have.
Jeroen
Good point. These might work.
And I knew I had seen these but couldn’t remember the brand, thanks this will work ![]()
Jeroen
