You have put some serious thought into this. Nice work.
I can’t answer your first two questions. For #3, **there won’t be any shifting compromise since 11 speed spacing is the same throughout cassettes. **
#4 is where you’re going to get a slew of opinions. I don’t really believe in a do-it-all cassette. I would normally pick out the cassette for the course. To me, a SRAM 11-28 makes a lot of sense because it holds really tight until going to the low gears. I like the climbing gears to have more spread (percentage-wise) between them. For reference, their 11-28 1170 cassette goes 11,12,13,14,15,16,17,19,22,25,28. If you anticipate a course with some hills and you’re going 1x, nearly any cassette will work with that 9100 rear derailleur. I would just find the one with the lowest gear you need for a course with steep or sustained climbs. 11-32, 11-34 (shimano), or 11-36 (SRAM) should all fit. I have a couple Shimano 11-32 cassettes and I don’t like that the 15 is excluded. **Given your desired gearing range with a 44 front ring, I would think the Shimano 11-32 might not be a good fit. **
The gearing choices for the EDCO and Rotor cassette do look appealing.
That’s what I thought. But when I inquired about custom Miche (from cycleclinic mentioned above), there were only particular gearing options he recommended. He wouldn’t send out a copy of the Rotor gearing, for example, because it will compromise shift quality to have those bigger jumps. Like you, I prefer tighter spacing in my fast gears, and bigger jumps in the climbing gears. That’s the nice thing about Rotor and Edco options.
11-32 gives me a range from 4.00:1 down to 1.38:1, which is all the range I need. I only use 4.33 to spin out while I’m flying down a hill, that’s it. The 1.38 should be enough for anything but Lanzarote.
Any consideration of the 9-32 3T cassettes? they would get you a 3.56:1 spread and would half step to SRAM AXS with the required driver body update.
Yes, I had it in my spreadsheet but it immediately got disqualified. It has way more range than I need and big jumps where I want small ones, unfortunately
Why are you interested in converting to 1x?
Your current setup 2x seems to accomplish exactly what you wish. What is the real net benefit of a 1x system that has less range and bigger jumps- especially in the range you prefer?
Yes, it accomplishes everything for 2x. But I caught the bug and want to get a 3T Torno crank set and get rid of the FD for the sweet sweet aero benefits. Since I use 11 of the 22 gears for 99%+ of my riding, the downside seems non existent if I can match those 11 gears.
You don’t want small cogs in your “cruising” range of 3.4:1.
Get a 48 for the front.
Get a Sram 11-28 for flattish races. That gives you nice 1t jumps where you will be the most.
Another option would be to combine a Shimano 12-25 cassette with something else, and drop the 11.
Get an 11-36 for hilly courses.
So weird, back in the day when we used freehweels, loose cogs were readily available; even though every freewheel model took proprietary cogs. With cassettes it would be very easy to allow customization, and yet no one offers it.
I think a 46 would be perfect for me because 48/11 is overkill, but a hear you. Unfortunately the 3T Torno comes in 44t max. On the flip side though, cruising in 44/13 compared to 52/15 shouldn’t be a big problem. According to Diamondback, I’ll only give up 0.5W because of that smaller cog :https://ride.diamondback.com/friction-profiles-1x-drivetrains
I think the Torno is likely worth more than 0.5W compared to other cranksets compared to, for example, the Easton EC90SL crankset, which also looks like a winner.
Funnily enough I was looking into something similar for my TT bike to take to Norseman. In particular I wanted 12-30 for Shimano freehub, which Shimano themselves don’t do in 11 speed.
I bought a Miche cassette. These guys will make you up a custom cassette from sprockets of your choosing, as long as you don’t ask for something silly.
UK but ship to US.
https://thecycleclinic.co.uk/...es-for-shimano-sram#
Cheers, Rich.
He says he will make a custom cassette but he wasn’t very receptive to it when I asked. Granted, I started off with something similar to the Rotor gearing which is more lopsided than SRAM/Shimano, and then added one more single-tooth jump before starting the sharper ramp in the climbing gears. He says the Rotor cassette is designed for the ramp of the Rotor derailleur. After a few emails I gave up and fortunately found the Edco which is also very similar to Rotor but less than half the price. Seems the issues with that cassette have been ironed out and that might be the best choice if I pull the trigger on the 3T Torno.
