My point is that the '06 TTX is a different bike than the '07-'08 Equinox TTX. Everyone seems to assume they are the same. My LBS thought they were the same, my receipt says '07 TTX - Black. It wasn’t until we started through the process of getting some warranty work that we realized the difference.
The question is, does he have to pay for the '06 TTX or is it just the hassle of building up another frame? And, does the TTX fit?
Also, I did some searching in this forum and found the following threads pertaining to the differences between the '06 TTX and the current Equinox TTX’s…
09/06/07 - '06 TTX vs '07 Equinox 9.9
Compleately different bike.
Go with the 2007 or even newer one. 2006 which was a limited production had a TT geometry. You can still flip the seatpost and adjust it but another thing is the frame material. They have changed the material, the difference is more than just $500
if you call trek directly they will give you more detailed info between those two but 2006 model is pretty much of a dead meat and most shops try to get rid of it. Don’t get me wrong it is a great bike I had the early version but it is NOT even comparable to the new one.
10/10/07 - Trek TTX is Faster Than the P3C
part of the confusion (here and in numerous other threads) is the generic use of “TTX”. There are three basic model families, across a couple years of production:
TTX - the original, roadie geometry, 1-size only
Equinox TTX - inspired by the above, steeper geometry, several other diffferences (1.125 steertube fork, some tube shape deltas both subtle and obvious, etc)
Equinox TTX SSL - lightweight version of the above
I claim no knowledge of head-to-head aero differences between the first one and the following two. But absence of evidence is not evidence of absence
Carl
(yeah, I work at Trek…it’s not a crime)
12/1/07 - Damon - Equinox vs. TTX. Drag differences?
IIRC, all Equinoxes (carbon and aluminum, new and old) share the same airfoil section for the down tube. Only the “plain” TTXes (no Equinox name, direct copy of Lance’s) had a slightly different section that we tried but abandoned (the production version is better overall, considering performance in all wind conditions). All have true airfoil head tubes.
Old aluminum Equinoxes share the same 1" Trek TT fork as the OCLV carbon Team TT model and “plain” TTX. (BTW, this is a fast fork, and we’ve never found a faster UCI legal fork.)
The new aluminum Equinox has butted tubing to save some weight, but still retains the same airfoil shape. The head tube is still an airfoil, but wider to accommodate the new 1 1/8" TTX fork, shared with the OCLV carbon Equinox TTX. This fork uses the same tips and blades as before, but the crown is shaped to match up with the down tube.
