Zones: HR vs Watts
Unless your 60 years old, I doubt your threshold is 148bpm. I just find that hard to believe… though it might indicate that muscles fatigue is really limiting you and you need to ride more, harder and with more structure. That’s zone 2-3 for most younger to middle age males. I think I average around 145 for my entire IM for comparison. My average HR during a 20’ FTP test was 159, 174 in a 1/2 marathon race.
This is also why I don’t like HR for cycling. It just varies too much I find.
1st , don’t use Max HR to determine threshold. You need to do a proper FTP test. Did you HR average just 148 during your power based FTP test? Thats the number you should use. Honestly, it will work OK, but not great. I prefer to just take a WAG and estimate it based on RPE when I don’t have power.
2nd if you going to use trainingpeaks as it’s intended for self coached multisport athletes, I suggest reading “The Triathletes Training Bible” so you can learn how to get the most out of your training. Best tip someone ever gave me.
Age has nothing to do with heart rate. An athlete who trains regularly will have a maximum heart rate which declines by hardly anything.
I used to run with a chap who was 16 years older than me. At the same pace I would be at 150 bpm and he would be at 180bpm, and he was 55 years old. According to the wankers in white coats his maximum heart rate should have been 156 bpm.
My maximum heart rate has declined only by about 5 beats per minute since 1983.
I don’t know where the men in white coats got this bell curve that says 220 - age, but it is bollocks in real life.
Ummm didn’t I state NOT to use max HR - age or any other formula. I said to use testing. But I think it reasonable to assume that 148 is pretty low for a healthy younger male athlete. Yes, it will decline as you lose the muscle density, VO2max continues to drop with age, and so on. Can this be countered by consistent decades long training? Yes. But not\w your introducing another variable and muddying the waters. The OP is clearly newer at this and less trained, or he wouldn’t be asking these questions.
I’ve been training with HR for almost 20 years. My HR in 5k races (most repeatable high intensity test for me at least, has dropped from around 205 to 190 in 20 years. So yes, less than 1 bpm per year. But my overall fitness is also much higher than it was 20 years ago FWIM… and focused on lower intensity aerobic. I think that’s the more important point.
That’s a good point I don’t know why I assumed the OP was under trained. Perhaps that was a poor assumption.
As a runner turned triathlete I was in the “under trained” bike crowd early on. My FTP HR was in the 155 range at the most. Threshold run HR about 165.
Heart rate is heart rate. Heart rate levels or heart rate zones are heart rate levels or zones.
Being vertical vs. being horizontal alone will create a larger “overhead” in running. That’s why cycling HR zones are more linear. You activating more muscles in running. It uses more core, smaller supporting muscles, your even driving your arms. In cycling, unless your FTP is over maybe 4.5-5 w/kg, and ride at 90+ RPM, your not using you core or arms all that much. They should be fairly relaxed.
The zones presented by Friel and Coggan are based on studies and meant to represent the engagement of different metabolic systems or changes in muscle recruitment. In their books however, it’s clearly stated that they are not rigid barriers and the zones can change day to day and the transition is seamless. The purpose is to create a somewhat repeatable and trackable measure for training that’s more accurate than RPE alone. The whole point is to be able to make a hypothesis (training plan) test it (train), measure the results, then draw conclusions and retest (train more). You know… scientific method.
I think I understand the question and to place the number it would be a variable. If I was pushing 210 for 2 hours at 140bpm i would probably boost my FTP. Haha. The base answer would be that no I did not do any additional work on Wed than Mon. It may be more of a stress due to workout load, recovery, etc. But the work output would be the same.
However if the goal is a zone 2 workout for 2 hours I would be pushing lower watts on wenesday IOT stay within the HR zone. Or stick to the watts and allow HR to creep into zone 3. Right?
If your goal is a quality workout, which is better: Work less to keep your heart rate low, or keep the work as intended and let your HR drift as you fatigue?
John
Sorry not with you there. You seem to be saying that when someone has an FTP of 4.5 to 5 watts per kilo they use their arms and core more than a rider with a lower FTP?
Did you mean this?
Also I would have thought climbing out of the saddle at low rpm would mean using arms more than riding seated at 90 rpm or above.
Not trying to argue with you just understand what you are trying to say.
I almost feel as if hr is as good as power cause you want to know how you’re responding to the workout if you ride 210 watts one day at 140 then another at 155 then you did work harder. A combination of both would be ideal but I think hr would be good on its own. In racing I think heart rate could be more valuable but I don’t have a pm
A 15bpm shift within a short period of time is exactly why you shouldn’t use HR. power is power. It’s the actually load/output you are generating. you don’t change your workouts intensity because your fatigued. You adjust your training load, typical by changing duration. But if you plan calls for a FTP workout, you either bag that workout if your too fatigued, or you do the workout despite the fatigue, then adjust your plan as needed. What you don’t do is train at a lower zone, because of fatigue. You metabolic system don’t change because you tired in cycling. Just muscle fatigue. Fatigue is independent of intensity, it only prevents you from achieving a set intensity. Does that make sense? that’s why you test you threshold paces when you’ve had a change to rest, not in the middle of a training block.
Let me put it this way. Your FTPs doesn’t drop because your fatigued. You just are unable to sustain that intensity as long because of fatigue. But at a cellular level, your body is still behaving roughly the same in each zone.
Let me put this another way, when you train, you are not training your heart. I think that’s a misconception. You are training your muscles to fire and generate work, as a result, your heart will get more fit as it too is a muscle. The heart is a input value an a indicator of intensity, but not as accurate as measuring direct output, power. In running, if you always ran on a flat surface and if your run economy never changed, you would use pace instead of HR. However, running pace is not linear and has too much variability due to economy of motion. But many times, it can still be better to use pace that HR when measuring running intensity, as your heart also has vairability.
The worst thing about HR for pacing, is that it can take several minutes to hit equilibrium. With power, you can get a good value in a 3-10s window wit ha rolling average. the change in intensity is captured with nearly every muscle contraction. Because HR is passive, just like breathing rate, it’s much slower to change. Running my last 5k, it took almost 1 mile for my HR to level out. 1 mile. If I had used HR, I am flying blind, the first 5-6 minutes. Using pace, I get a good value in 10-15 seconds. Using power going up a steep climb, 2-3 seconds.
So if HR is as good as power, how do you pace 30" or 60" intervals on the bike. The intensity might be 150% of FTP. HR would be 180 if at a steady state, but if your very fit, and you recovery is low zone 2… guess what, your HR rarely goes past an indicated z3 HR, even through your well into zone 5. Meaning for intervals under 10’ or so, HR is useless for accurate pacing you’d have to go by feel, which means you might as well use nothing a guess.
I know what you are trying to say.
You know it’s interesting, but what I’ve learned most the last year, is that your really training muscle adaptation, not really your cardiovascular system. Cardio system adapts in response to muscular adaptation. But I think that’s a little bit harder to picture for people. You feel muscle fatigue. You feel breathing rate. You can feel your pulse. You feel sweating, general fatigue. You don’t feel all the chemical processes occurring that allow your muscles to contract.
I see how power is more useful in training but heart rate would be better for pacing in the long haul race. Like it doesn’t matter what watts I’m putting out if my body’s response can’t sustain that I’m worried about sustaining maximum performance not sustaining a number of watts that might be too much for my body in the moment. Like if you have both that is clearly better but I think heart rate alone could be enough if used properly
And I’m not Trev.
No? Well you do quack just like him…
Hi everyone, For me I found that both HR and power helps. I use Virtual Power on my trainer and when I am working on zone 2 and zone 3 I go by my HR. As the weeks go by my HR will get lower then the fatigue get go up and It get harder to meet the zone power and HR. After I do the rest and recovery week I can ride at the higher end of the HR zone mush easier and the power out is higher. So when I am fatigue lower HR and hurts the leg to meet the power zone or HR zone. After rest everything is easier and higher power output. Then I adjust all power zones and keep the HR zones the same. I think we want to work our power up in each zone. if I could tempo HR about 150bpm for me the more power the faster I will be. When I am doing intervals above the 100% (FTP) line I use power only. HR legs behind.
