Zipp VumaQuad- Are they any good?
I am thinking about getting some new cranks for my tri bike. I have Ultegra SL with ceramic bearings right now, but the crank arm feels too short. My lbs keeps pushing the Zipp VQ cranks with ceramic bearings. Everyone has them tells me they are great, but they seem very $$$. Any thoughts on whether they are worth it?
I have them and like them. Super light, shift well and look cool. I just picked up some used compact rings for them too for uber cheap (which is also how I bought the cranks) I’d never pay retail for them since other than being really light I’m not sure they are any better than less costly options, but if you have the coin they are pretty nice.
I did switch from Ultegra to the Zipp and haven’t regret it.
You also might want to look at this
http://fairwheelbikes.com/forum/viewtopic.php?f=77&t=5468
All the good cranks are expensive like the Storck or the THM
http://i32.tinypic.com/2rco4cj.jpg
I love my VumaQuads. I just bought the standard bearing since they are extremely smooth. Worth the money? Yes they are.
double the cost makes you double faster!!
cranks are cranks.
the most important things are BB that don’t fail too often
and looks
unless you have a brazillion dollars
then go ahead and get light and aero ones =)
the VQ cranks with ceramic bearings will make you maybe, 1 second faster over 40k TT because they are lighter.
If it’s for your tri bike, I certainly wouldn’t go with longer crank arms. I can’t ever imagine cranks feeling too short on a TT bike. Maybe on an MTB.
I rode the VQ for a long time. I really enjoyed it. As with most things, you are paying a lot for a relatively small drop in weight, which will likely only matter on steep climbs.
The most compelling reason to get the VQ, I think, is the fact that it has a narrower Q-factor than just about any other crank out there.
It’s first rate craftsmanship, but the Ultegra crankset is a wonderful crankset as well.
The stiffness:weight of the VQ is much higher, but that’s because it’s much lighter and equivalently stiff, not because it’s much stiffer.
There are plenty of upgrades I’d make before I invested in a VQ. But if you want the latest, lightest, best and already have everything else, then yes, it’s a wonderful piece of equipment.
TRUE!
since aero trumps weight though, you may want to consider the vumachrono…
I have them on my road bike (my project bike - but it is what I ride the most, not my TT bike). Light, pretty stiff - not as much as Dura Ace ones, but still get the job done. I got the ceramic bearing model.
Here is my “install tutorial” that I wrote up on them after I installed them for a couple of really good pics:
http://www.beginnertriathlete.com/discussion/forums/thread-view.asp?tid=130665&start=1
If you’ve got the money, go for it! I also would not use these on my TT bike as they only go up to 175 and I have 177.5’s on that bike. I think the Vuma TT cranks may come in longer sizes.
