Zipp Vuka question 2
Yes, here comes another Zipp Vuka aerobar question: I just bought the bar and I have not been that lucky assembling it. It got some scratches (which I was told did not influence the strength of the bar - however, it very much influenced my mood) and now when installing the brake cable housing, one of the smal plastic grommets installed under the base bar, broke. I am not sure if I can run the bar without the grommets or whether the cable housing will move and damage the carbon bar when riding the bike. I am quite tired of damaging my brand new bar, so I would very much appreciate you guys’ advice before moving on.
I also asked Zipp the same question, so if anyone from Zipp sees it here, I apologize for repeating.
Those platic pieces barely stay in on mine, I wouldn’t worry about it. When you’re all done just call zipp and tell them it broke and they’ll probably ship you a new one for free. Just save it until you take the cable apart the next time.
I’ve had mine for 2 years and love them. Don’t worry about the scratches, you’ll get more plus it makes you look like you actually use your bike! I actually have a layer of electrical tape just in front of the colletts so my aerodrink holder has a better grip.
How did the plastic cable guide break? There is nothing to break… You just slide it on once you are done cabling and snap it in place… Anyway, I am sure you can get a replacement. But, it shouldn’t really make any difference at all in terms of performance until you do.
I also find it an interesting manifestation of human psychology to read “it got some scratches” and the “plastic grommet … broke.” Not “I scratched the extensions” or “I broke the grommet.” (Just giving you a hard time…)
Well, yes I admit that I scratched the extension…when slipping them into the collets as described in the manual. The grommet has a small lip to make it sit in the bar…the lip came off the grommet when I took it out from the bar (by hand…not even with a screw driver as proposed in the manual). My fault? Maybe…however…seems more fragile than I expected.
Thank you for the advice. However, I was just adviced by Zipp CS that I should not use the Vuka bar if the grommets are not installed as the cables might cut into the carbon. Not the advice I had expected or hoped for, but I will of course comply.
Now, living in EU, it is always a challenge to find a Zipp dealer which actually has some spareparts…
