I was searching through posts from the past and noticed there are quite a few on valve extenders, but I still have questions. I purchased new tubular 404’s this past spring. They were my first tubulars, and I love the way that they race; however, pumping them up has been a nightmare. There are two problems I seem to have and I believe that together they cause a bigger compound problem.
Problem 1: I am using the dark/black zipp valve extenders; however they are not taped on, nor is the presta valve in the locked open position. In fact, the valve comes off and I have to attempt to screw it back on every time I inflate. I can never get an accurate reading. I have learned how to remedy this problem based on other posts.
Problem 2: The zipp valve extender does not seem to fit the adapter on either of my pumps (both standard Blackburn pumps I purchased at B&L in San Diego). Once I have clamped the pump down on the valve extender, I can not seem to get the valve extender off. The lip or top of the valve extender is too fat.
Compounded Problem: When I can not get the pump off the valve extender, then I have to resort to using a wrench to unscrew the valve extender from the presta valve while the valve extender is still inside the pump clamp adapter thing (I don’t know the name for that part of the pump). Then I have to use every muscle in my body to get the valve extender out of the pump. I know there is something wrong with this.
I can see that I need to remove my tubular tire and open the valve completely and attach the valve extender so that it is tightly attached to the presta valve of the tire and then tape it. However, once I do this and attempt to inflate, then I will be SOL, because I will not be able to remove the valve extender from the pump adapter clamper thing.
This brings me to 3 questions: What pump do you recommend that will work with the zipp valve extenders? Are there other valve extenders that are smaller or fit better than the standard zipp valve extenders? How in God’s name do I remove the tubular so I can remedy this situation.
