Zipp super 9 disc brake carbon clincher
Hello,
I want to buy a Zipp super 9 Disc-brake Carbon Clincher Disc.
I found this wheel on a website but I do not understand because the specifics noted on the site (https://www.bikester.co.uk/...no-black-621470.html) are not the same as those I find on the website https://www.zipp.com regarding this wheel.
It is noted that this is a 2019 model and that the hub is a Zipp 188D V1, with an axis of 10x135mm and a 6 hole fixing for the disc. I contacted the website and they gave me the EAN number of the product: 0710845795206
Or on the website https://www.zipp.com (https://www.zipp.com/...arbon-clincher-disc/) I see that the hub is a 77DD compatible with a 12x142 thru-axle (which I need for my bike) and with a centerlock mount for the disc.
Can you tell me if the two products that I compare are the same or if there are two super-9 disc brake carbon clincher different (one with a hub 188D V1 and the other with a hub 177DD)?
Thank you for your help and sorry for my english.
The disc wheel on the bikester website won’t fit your bike.
The image on the bikester website shows a rim brake carbon clincher disc (red driver body is the main giveaway) and the description is of a rim brake disc.
The finished good part numbers for disc brake carbon clincher discs are:
WH SP9 CC V1 DB 700R SR 11S WHT 00.1918.321.000 (white decals)
WH SP9 CC V1 DB 700R SR 11S BLK 00.1918.321.001 (black decals)
