I’ll try to answer some of the questions bob had but mostly Tai is right on.
The increased impact strength is just for the tubular rims, the clincher rims are already nealry bullet proof and are quite popular with the 29" mtn bike which more than proves their durability. The 2007 tubular rims see about a dozen layup and material refinements which increase the strength with no weight penalty over the 2006 version.
The zero stars for the 606 for training was a catalog mistake, it should have been 2 stars. We only recommend training on your aero wheels if you are training with power. Since most people train by speed or on group rides, training with your aero wheels just makes you ride less hard and burn fewer calories than training on std wheels, so we discourage training on any aero wheels unless you are training exclusively by power.
All of our rims are designed around a 21mm tire. When working in the wind tunnel or on the computer you have to choose a tire width to design around and we pick 21 as it is a nice blend of aerodynamics and low rolling resistance, plus it is a widely available size. We were the first company to really do this as previously all aero wheels were designed around 18 or 19mm tires, which I feel are just too narrow, two flat prone, and must be run at too high a pressure to prevent pinch flats that they ride harshly. You will see that most aero wheels see as much as a 20% decrease in efficiency when used with a 21 over a 19mm tire, whereas all of our stuff was designed around a 21mm tire to begin with and in most cases the Zipp with 21mm tire is faster than any other wheel with a 19mm tire. In testing done by Tour Magazine in Germany 4 of the top 5 wheels are Zipps including the top 3.
As for the pricing debate, this raged on here a few weeks ago and I think is largely the result of people comparing apples to oranges. The Hed Jet is simply an aluminum wheel with a carbon fairing bonded to the aluminum rim to add an aero component to the wheel. This is a very inexpensive way of making an aero wheel and has been used by numerous manufacturers to build an aero wheel at a very low cost. The Jet is simply a price point aero wheel and if you are going to make a comparision, you need to compare it to the FlashPoint wheels from Zipp, which at the same price point offer a better hub, DT spokes, and a fully structural carbon rim with welded aluminum hoop utilizing two of the patents also used in Zipp wheels. I think that when you put the Jet up against the FP wheels, the FP wheels are the clear choice, but that can be debated. A more fair comparison would be between the Zipps and Stingers, although the Stinger uses the same hub as the Jet, which is not quite as nice as the hubset used in FlashPoint. The Zipp wheels use a hub which is made in the USA and to a level of precision higher even than Chris King, and actually costs slightly more than the King hubs due to the ABEC5/grade10 swiss bearings, these bearings alone cost more than a good hubset made in Asia and are higher grade than most ceramic bearing upgrades that people are offering. Combined with the Sapim CS-ray spoke, the world’s most expensive and most fatigue resistant spoke, and the lightest handmade rims available and you end up with a very expensive wheelset. Every component is manufactured entirely in the USA from US materials except for the spokes from Belguim and Bearings from Switzerland, we use absolutely no Chinese labor or components, in fact two of the carbon fiber grades we use are considered ‘defense critical’ and only available in the US. This does keep cost high, but allows us to innovate continually and revise and improve much faster than using overseas manufacturing. For example, we made more than 10 laminate revisions this year as we found new materials, or new layup concepts, we can continually improve and innovate as our engineers are located 20 feet from the production floor, compared to working in Asia where you innovate only every 3-5 years. In the last 5 years we have seen 4 rim shape revisions to the 404, the development of the 808, 5 generations of 303, the creation of dimpled composite technology and with it the tooling manufacturing technology necessary to manufacture this, the first use of ceramic bearings in the bicycle industry in 2001, we were the first company to push for the development and then adopt butted/bladed spokes, and numerous others resulting in more than a dozen patents issued and pending. The hubs are another example, we made over 20 improvements to the hub this year including the bicycle industry’s first use of wire EDM for manufacturing of the drive components making the highest precision hardened components ever to be used on a bicycle in components that are rated at 60-62 Rockwell C with precision greater than 0.000002"…3 years ago this was technology so expensive is was only being used for surgical implants and missile guidance hardware manufacturing…but the result is that the rear is now only 176 grams and the front 80 grams and roll with the lowest rolling friction of any hub ever made, and in their stock form beat out every currently available ceramic hub upgrade.
So in defending our pricepoint I think that you have to realize that we are doing something completely different from anybody else. We are creating, designing, and manufacturing our own product from scratch in our own facility, with an eye on absolute refinement, highest possible precision and greatest efficiency…and not focusing on hitting some specific pricepoint where we say we want to make the fastest possible wheel for X dollars…that is what FlashPoint is for, with Zipp we go as hard as possible to create and develop technologies to be the best available without a primary consideration on cost, so when you buy Zipp you know that what you are paying for is the absolute height of technology available at the time you spend your money and nothing less.
cheers
josh
