Zipp Disk compatible Tubulars
I got a flat in my Zipp tub fitted to my Disk I brought last year. I fitted a Vittoria Corsa Evo CX but have hit a problem it is almost imposible to fit the crack pipe in to pump it up as the valve is too long. I don’t know if there is a smaller less tall crack pipe available? If not can anyone recomend a simalar performing and priced tub that will fit/
Thanks,
Tim
Nope, you are screwed. Just ride it flat.
Also, avoid turns.
Chris
From the Zipp website:
Please note:
The 50mm valve connector on the first batch of Tangente tubular tires is too long to work with older style (pre 10/06) Zipp discs with a shallo cut-out. You will need to find an alternative tire with a 32mm or 36mm valve connector to fit comfortably and still be able to apply air using out disc floor valve adaptor, e.g. Velofllex 36mm. All subsequent shipments have 36mm connectors.
