Zipp Conversion 10speed to 11 Speed $250
$250 doesn’t seem overly expensive considering that you get a new freehub body and they have to re-dish your wheel.
You’re right, it’s not too bad, but it doesn’t compare to ‘free’. However, the biggest issue with lots of athletes, is that they have great wheels that you can’t convert from 10 to 11 at any price, well, short of fully rebuilding the wheel. That’s why we did our approach. Free and easy, perfect shifting.
Sorry, no I wasn’t (there, or rather here)! Work/travel got in the way. *Is *in the way, actually, as I sit in a hotel room typing this.
I’ll have to rummage through my bike parts bin for the bag holding the conversion kit left-overs, but it has the conversion kit # on the bag so you can order same. Essentially it was a new axle, seals and freehub and was for v.7 “beyond black” 188 hubs. There were no other parts in the kit. The axle diameter on v.7 and v.6 hubs are the same, so I simply used the freehub from the conversion kit and just re-dished the wheel about 1.5mm to the NDS.
One thing to note, the conversion kit I bought had a machining error in the freehub’s cassette locking nut thread, so I had Zipp send me a new one (free of charge). Apparently this was a known issue for the kit I bought.
I doubt I’ll have the time when I get home to dig it all out, as I go immediately to Chicago to run the marathon this weekend, but perhaps next week if I think of it I’ll snap a few pics and get the parts # for you so it all makes sense.
Dave
I have a lot of 10sp wheels which I feared kept me from buying any new gears as all is now 11sp, but I discovered that ALL recent campagnolo freehubs will run 9sp, 10sp and 11sp cassettes. Also, and here is the key point, Shimano and Campagnolo 11sp have identical spacings, so you can run Shimano 11sp on a campagnolo cassette with perfect shifting. I put 6870 Di2 onto my wife’s bike using a “campag” wheel with a new 11sp Chorus cassette and it works flawlessly.
The only minor challenge is setting the “low” adjustment screw on the largest sprocket so that the derailleur allows the chain to run in the gear, but without the very slight ping of pulley cage on spoke.
So just change to campag freehubs would be my recommendation (and is what I will do when the time comes …)
Not identical, but they’re close.
The bigger problem: many 8/9/10s wheels out there simply do not have a campy freehub option. It’s not available at any price. And that’s when this idea is an easy solution.
