For rmur: we have seen the best results with Zipp rims and wheels using 21mm tires like a Vittoria CX, Zipp tire, Veloflex, etc. Much of the last 3 years of research, however have been on making the rims work optimally with 21-23mm tires, since that is what the European pros and most roadies ride, and what we feel most triathletes should use as well. Our rim shape is interesting in that it allows us to tune to this tire effect. From what we have seen of our old rims and other non-Zipp patented rim shapes (this includes 3 spokes) is that you want to run a tire equal to or slightly narrower than the rim. A wider tire will simply leave the rim in its draft, negating much of the aero benefit of a deep rim. Personally I think 21-22mm tires are optimal in size due to the amount of casing deflection necessary to make a good contact patch, and prefer cotton casings and latex tubes, both of which have proven to be of lower rolling resistance than nylon casings or butyl tubes in all the testing I have ever seen or been a part of (note: much of this testing has been done at universities competing in the Supermileage vehicle championships, which last year was won using Zipp ceramic bearings). 21 is also a good width as it runs ideally at 12-125 for most folks, so you have minimal rolling resistance at a pressure that is comfortable and offers good grip in most any circumstance. I think people get themselves in trouble trying to run 19mm’s at 150psi or something where you have almost no rolling resistance advantage, but are beating your body up quite a bit more than necessary, and have sacrificed a large percentage of total cornering power of the tire (especially in the rain) also, for tubulars, narrow tires at high pressures will wear much faster causing you more out of pocket plus more frequend gluing in the long run.
fbrissette, thanks for pointing out those errors, for some reason our software doesn’t seem to like the ^ notation, so we will try something else. Look for 1E4 and 1E7 to replace the 104 and 107 shortly.
Boz, you bring up an excellent point about more macro scale testing, and I will tell you the thought process and history of this issue. We were the first company to actually test front wheels with forks some years ago, this was the early testing that showed composite spoke wheels requiring 3-5 watts more to spin in a fork than without one, and leading to Zipp dropping the model 3000 3-spoke wheel from the lineup as the then ‘440’ deep section wheel was faster and cheaper. However, subsequent testing has shown spoked wheels and discs to behave in a relatively piecewise manner (for front wheels especially) such that if a wheel has a pound of drag and the bike/rider has 4 lbs of drag, then the system will have 5lbs or possibly 5.05lbs of drag, but the math is very consistent. Unlike composite spoked wheels which demonstrate high dependance on surrounding frame members, and we see that a 1lb drag composite spoke wheel in that same system may have 5.4lbs of drag with one fork and 5.2 lbs with another fork.
The other reasons for not using bike and rider in wheel testing is due to extraneous ‘noise’ created in the testing which makes is difficult to say is a change in performance is related to the variable you want to change, in this case the wheel, or due to something external, such as a rider moving his head slightly, or changing finger position on the bars. For your assertion that they don’t test aircraft like this, I have to disagree, the walls of the A&M wind tunnel are covered in photos of landing gear hanging from the tunnel ceiling, rear tail-planes and horizontal/vertica stabilizer assemblies mounted on ‘torpedo’ fixtures, and endless wingtip models testing various endplate and winglet assemblies, as well as dozens of Indy and Champ car noses, wings, rear wing assemblies and cockpit surround models, all lacking the rest of the car.
You are correct in saying that you can’t just take the wattage or drag force in pounds and make exact time estimates, but after years of modelling this, as well as testing bike/rider combos with various wheels, we have rather accurate computer models which can predict performance gains. You will notice in some of the time estimates that the 808 will save you more time as a front than in the rear, and that a disc is only slightly faster than an 808 rear, much of this comes from theory of how the bike/rider combo shields the rear wheel slightly and we have repeatedly see in all sorts of frames that the rear wheel is ‘faired in’ by surrounding frame and rider by 25-30%, however, since the frame/rider will fair in all wheels the same, we can model that a faster wheel will still be faster, although by a diminished amount. Other studies have been undertaken to try and undestand the effect of composite spoked wheels in various fork assemblies and rear ands, as well as lens discs vs. flat in narrow rear ends where it seems that flat discs have the advantage as the disc surface is held farther from the frame members and their resulting boundary layers, but there are just too many variables to feasibly model at any cost. Fortunatey, it has been shown that the downstream members of the bike will not affect the front end airflow, so the only factors in front wheel modelling are wheel, tire, and fork, and as I said, for spoked wheels, the fork has proven to be very simple to model.
To give you an idea of how much time these tests take, the testing you see here was undertaken in February of this year, and took 5 ten-hour days to finish development of the 808 rim shape and new 404 shape using 3 different tires, and then run a simple test on wheels with 5 different spoke counts using the same rim and another on 4 various spoke shapes using the same rim, just adding a single fork to all of this would double the time necessary, and no doubt leaving people to wonder about the fork they use that we didn’t test. Since each run was repeated a minimum of 3 times for accuracy (a first for the industry), the testing has to sacrifice number of variables, for accuracy of data, and since we specialize in wheels, that is a sacrifice we feel is justified. Since wind tunnel time costs about $500 per hour, plus expenses to get everybody there, hotels for the week, make all the models and ship them, feed everybody, etc, so you can imagine the expenses involved in even adding one variable to the test protocol. From the last 4 years, the biggest advantages we have found in the tunnel have all come from working to better blend the tire and understand what we call ‘tire sensitivity’ of these wheels, so we tend to focus on rim shape and this new dimple technology. If we made composite spoked wheels still, we would probably be focusing on boundary layer interactions between the spokes and frame members, but since we don’t it is poor use of funds to really focus on that, so we’ll leave that study to someone else.
The data you want would best be found at a wind tunnel camp, where riders are able to actually get in the tunnel with their bike and wheels and so on and see the numbers. We also have long history of experience with riders and bikes in the tunnel, and can tell you for certain from our later testing this year with Ivan Basso and Carlos Sastre (with cervelo at MIT) that the 808 data from A&M was again verified with bikes and riders in place, but the focus of that test was on rider positional improvement, and there was no time or ability to perform wheel testing, just as if we had used riders and bikes in our wheel testing, there would be no time for changing rider position to see if it has an effect on wheel performance as the added variables become overwhelming.
In the end, I think we all realize the complexity of the bike/rider system. It is in many ways far more complex than aircraft or even racecar modeling due to the human element and all the exposed moving components in the system. Fortunately, we are reaching a place where many companies have good data on their products, and many are starting to collaborate or at least discuss openly their findings and theories in an effort to make better systems. Frame companies are trying to make forks that work better with all types of wheels, frame makers are trying to better blend airflow onto rear wheels, etc, and as a result the entire system is getting faster, and most all of this research is based up front at least on the piecewise models theory. One great example is Trek, who has worked for a few years to develop a fork specifically to function better with composite spoke wheels in an effort to get back those few watts lost to flow interference between the wheel spokes and fork blades, and now even tout this improvement on their website and are selling that fork in the aftermarket, Cervelo I know has undertaken similar measures with their fork designs. This is a dramatic shift from the Hooker or Cheetah concept of making a system of parts that can only be used with itself (and quite a bichin system both are!), the new idea is to let people choose whatever products they want and know that all components have been designed not to adversely interfere with each other so that they can each perform to their intended design, and that I think is a real bonus for consumers.
