Thinking about getting a new rear wheel.
Any feedback on the Zipp 808 vs Hed Jet 90 (clinchers). The both weigh about 1050 grams but the Hed is $725 while the Zipp is $1200. Plus the Hed has a deeper rim (90 vs 81 mm).
Seems like the Hed is a better overall value, if not more aero?
Yeah, the “advertised” weights are often different in reality. The Zipp will be lighter almost for sure. Also, the Zipp uses a much better hub.
But, the HED is deeper and that is what you want. The Blackwell 100 and Planet-X 101 are even better still (but not clincher yet). I’d go with the HED as well.
Thanks all for the feedback. Regarding Zipp weights; the tubulars are for definitely much lighter but the advertised weights of the clinchers seem to be about the same as the Hed’s.
BTW I have Hed Alps and am very pleased with the weight and stiffness.
Are the Jet 90’s stickers baked under the enamel???
I am also contemplating a Jet 90 (Not C2), to replace ZIPP 404 front, and the choices are basically FP80 or Jet 90. The 90 should in theory be faster, right?
I went thru the same decision process earlier this year, only for a front wheel.
I got the HED Jet90 C2.
Initially, I kinda thought maybe I shoulda spent the extra beanos, but now w/ numerous races (and numerous PB’s) on it, I am VERY happy with it.
I sprung for the $60 ceramic bearing upgrade, and also got the black and white stickers (which go perfectly w/ my B2).
It is a fast, smooth, light, badass wheel. Add Bonty RXL Pro tires and Michelin 18-20 latex tubes, and you are golden.
PS - save yerself some $, get a disk cover from wheelbuilder.com for the rear.
I wish I could take credit for the SMART decision, but you were one of the folks who advised me to do it! : )
And you (and Tom A., and a few others) are on the very short list of folks I take bike gear advice from.
So thx!!! I owe ya a beer. (heck, I’ve owed ya several beers for various other things already)
Thanks. I noticed that the Jet HED 90 (non-c2) and Flashpoint FP80 are both on sale for about $500 shipped on trisports.com. Any thoughts between the two for a FRONT wheel? Running 303 w/ cover in the rear currently, and 404 in the front.
I measure outside to outside with a simple pair of calipers. Another way that provides qualitative results is to place a straight edge (metal ruler, etc.) perpendicular to the tire. If there is a gap between the straight edge and the outside edge of the rim, then I’d suspect that the tire may be too wide.
Thanks I’ll check it out.
I have been meaning to consider skinnier Evo CX tires for fast TT courses on smooth roads.
I am a small rider and never had any trouble with the winds riding 808 on front, altough I live in Brazil and the winds here are way more calm. I think is only a matter of driving the bike properly and in accordance with the conditions. Today, I would have gone even deeper and buy a 1080 as tge front wheel.
