I wonder how many more years we are going to get an obligatory “Flo wheels!” post in every wheel thread when when they still don’t exist and still have no comparative data or firm pricing.
X2
X2
FLO60 , flocycling.com
(but if you’re actually set on those, H3s are cooler and consistent across yaw angles, 404s are versatile for road cycling and have the benefits of spokes (tunable). H3s are reputably bombproof but could go irreversibly out-of-true. So if you’re going to race road, I’d go with the Zipps. That being said, I’m still for getting a set of FLO60s and then putting the saved money towards whatever
powermeter Rappstar recommends).
Thanks for keeping us in mind.
Does anyone know if they’ll have any wheels available for this season?
We are scheduled to get our final prototypes in January. Assuming all is ok with the final prototypes our pre-order will follow shortly after. We are hoping early February. Plenty of updates coming soon. It is getting close!
Take care,
The FLO wheels look promising but between the two you listed, Zipp would be more versatile + higher resale. Also some decent pricing on the non-firecrest wheels.
Take care,
It appears your 60mm is a faster front wheel verses the 90mm If so, why the 90?
Take care,
The FLO 90 is faster until about 12 degrees of yaw. This is actually a common trend in shallower vs. deeper wheels. It’s often said that faster riders will benefit from a deeper wheel since they are travelling at a greater average speed and therefore experience on average a shallower yaw angle. We have not done any specific optimal speed calculations but the industry typically says if you are averaging 24mph or greater than the deeper wheel may be your best option. It’s tough to say specifically since wind speeds and angles are so variable.
For most, the front FLO 60 will make a better choice. When choosing a rear wheel the FLO 60 and FLO 90 both have their benefits. Both are very aero so the choice comes down to the wheels intended use. If you are more concerned about weight and are not overly concerned with using a wheel cover then the rear FLO 60 would more than likely be your best choice. If you are planning on using the wheel with and without a wheel cover you may want to lean towards the rear FLO 90. I say this because our FLO DISC is based off of the FLO 90 shape. Adding a wheel cover should give you nearly the aero benefits of our FLO DISC. This doesn’t mean the FLO 60 will not work with a wheel cover… I’m simply saying our FLO DISC which has negative drag for more than 10 degrees of yaw was based on the FLO 90 shape.
I hope that helps. Let me know if you have any additional questions,
