Zipp 404, change hub to campy and back
If I buy a set of Zipp 404’s, whit shimano free hub. How difficult is it to change back and forth between Campy and Shimano and where do I get the necessary parts and tools, which are?
thanks
Depends on what model zipp hub, i’m sure zipp has a tech page that will give you all the info you need in determining your model and the steps required, if it’s there new “quick change” cassette body, then i assume it shall be a relatively easy and “quick” proposition…
If it’s an older hub you might need to redish the wheel. I use to switch wheels between my 9 speed shim. tri bike and 10speed campy road bike all the time. I used an american classic conversion cassette. Later on, on the tri bike I ended up frictioning the shifters, running a ten speed chain, and now i don’t even have to change out cassettes.
I’m looking to buy a set, so they will come with the new quick change system. However, I can’t find any information on the zipp homepage of how quick the change is and what I need to buy to do it.
If you go to nytro.com for example, it says in shimano or campy. But if the change is so quick, why decide? I want both in one…
