So the last few days I have had a few things where the thought occcured, “I should have just spent the money and got the good stuff”. Whether you are trying to cut back spending or whatever the reason is what have you bought and then realized " you get what you pay for"…here is the start for me and I realize there are many more so lets hear about it so I will be prepared next time.
cheap aluminum foil, it sucks!
my garden hose, always kinks, leaks, cracks should have bought “never kink”
generic barbecue sauce, never again!
what happens most often with me is that once i buy something, i regret not getting the (more expensive) next model up. not because it’s a piece of crap, but because the other model is just better. this has happened with:
tri bike
mountain bike
camera (D40)
this hasn’t happened with:
new road bike
car
prime lens (50mm / f1.4)
carbon wheels
Coffee makes and toasters, most definitely. Tough even to find ones that are decent quality and don’t fall apart quickly - the market is flooded with cheaply made ones.
Cookware, also. Not so great to be ingesting little pieces of Teflon.
Cheap plastic wrap (the clear wrap for food) is the absolute worst. Seriously, the store brand stuff is useless.
It doesn’t stick to the sides of the bowl when you wrap it over something.
When you use the edge of the box to cut it, it instantly binds itself into an unusable mess. How can it not stick to the bowl or dish but stick to itself like glue?
The box is crap, typically falls apart, and you end up cutting your finger with the serated edge when it comes apart from the box. Again, how can the serated edge do such a shitty job of cutting the wrap but slice through you finger? It’s the worst!!!
Seriously, it’s a sign of the times. I read an article the other day about how many luxury vehicles can be seen in the WalMart parking lots these days. I try to avoid the dollar store stuff as it seems to be the worst examples of what you are describing.
NEVER EVER use the “Off brand” spray on glue for tacking up corner protectors on drywall. Just don’t, seriously EVER, you’;ll hate yourself.
Buy 3M and go get the job done.
I also think there is a HUGE distinction between “Buying cheap crap” that you’re going to use once or twice and “Buying cheap crap” that you expect to use A LOT.
Some of the cheap crap just doesn’t work, not even once…see the above 3M comment. Other “Cheap crap” works, but not as well. Using it a few times to get something done, fine, using it 8 hours a day for a week…HELL NO!
