Could someone please explain to me, in plain English, the theory of compact cranks, and why someone would use them over conventional length cranks.
Gracias
Gracias
Really it comes down to rider preference, as long as you are using the same gear inch, not including friction from some combos, it matters little which chainrings and cog sizes you use:
http://www.sheldonbrown.com/gears/
Also, you can stay in the big ring longer on a 50 when climbing without running out of cogs.
We sell Rotor cranks to riders who use our 36/50 compact chainring combo, as well as the standard 39/53 sizes. They both work very well.
So, a compact crank of 36/50 gives you more cogs for climbing than a standard 39/53?
Don’t you give something up on the other end?
You give up top end speed.
Usually compact cranks run 34/50 chainrings giving a spread of 16 teeth rather than 14 with a 39/53. That means one less redundant gear between the large and small chainring and so more usable gears than the 14 tooth setup. It also means the spread between the biggest and smallest gear is bigger. The result is a larger gear range with the same size jumps between gears. You give up top end speed only if you’re running a 53X11. Otherwise you can match gears by dropping one tooth off the small cog (50X11 is a slightly larger gear than 53X12).
"Don’t you give something up on the other end? "
Yes, that is why many TT racers use a larger (54-56T) chainring, so they can apply constant power on downhill sections without running out of top gears. I use 42/54.
I use 42/54.
We all know that is for women and pre-pubescent boys Gary, come on! (Nevermind you beat me at the Toms Farms TT, that doesn’t matter)
I was embarrassingly un-aero (rode the hoods of the road bike, Open Pros/Powertap for data). I really need a TT bike. I would have likely gone sub-23, I hope.
Avg watts: 289, cadence 85, and I only went 24 MPH for the 10 miles.
Looks like we had the same set-up, road bike with Open Pros, but no PT for me.
“The result is a larger gear range with the same size jumps between gears. You give up top end speed only if you’re running a 53X11. Otherwise you can match gears by dropping one tooth off the small cog (50X11 is a slightly larger gear than 53X12).”
If this is the case, why doesn’t everybody use it?
I woould think because it is lighter. No i would guess that is is not the taditional set up. I believe that compact first showed up on MTBs back in the 90s but I could be wrong.
JW
Butterworth’s article pretty much sums it up.
Why am I not surprised Slowman had something on the site about it already?
Here we go again…
Butterworth does not understand this at all, and says a few things that are non-sense.
You CAN’T get MORE RANGE and TIGHTER SPACING at the same time. It is physically impossible.
The only reason why compacts are usefull is that 95% of cyclists are overgeared with the standard 53-39 combo. Hell, even the pros are overgeared on some very steep climbs with this combo. Compacts will give you the option of getting easiers gears within the range of existing cassettes (that means sacrificing top gear, or getting wider spacing).
With a 53-39, assuming that 11 and 27 teeths are the possible range with cassettes (unless you go with a mountain rear derailleur) you get possible gears ratios (depending on cassette) between : 1.44 and 4.81 whereas your possible range on a 50-34 compact is: 1.26 and 4.54
Unless you are running your compact crank with a 12-25 cassette or a 13-27 you get NO gearing advantage with a compact that you could not get with a standard crank. The rest of the arguments (weight, shifting ease, chain cross-over, double shifting) are awash and make no difference in the real world.
Having said that, I think all bikes should come with a compact and a 12-25 cassette. The very few who really need to pedal hard above 50 kmh could switch to an 11-21 cassette or switch chainrings. Unless you can hold 400 watts for an hour, why the hell would you want the same gearing as pros ? Compacts are about giving easiers gears and THAT’S ALL ! Nothing magical about them.
Francois in Montreal
You are right about 2, 3 and 4, but wrong about 1. You can’t get more range and tighter spacing. Between your highest and lowest gear ratios, you only have 16 additional gear ratios (for 9 speed bike, 18 for 20).
What is important is the spacing of gear ratios and not the spacing of the cassette gears. This is how spacing is defined.
Of course you can. There’s less overlap in gearing using a compact setup. Check out the article on Slowtwitch’s Tech center on compact cranks or do the math yourself at AnalyticCycling.com or some other site.
The article by Butterworth is incorrect and should be corrected or removed by Slowman since it mines the credibility of other articles.
Let’s do this mathematically, and let’s not even talk about gear ratios.
Take numbers 5 and 50 representing lowest and highest gears (not important if it is from a compact or standard crank).
Than let’s take 10 and 40 representing again lowest and highest gears.
The first set obviously has more range. If you have a 10 speed cassette, you get 19 gear intervals.
Case 1: (50-5)/19=2.63 (2.63 represents the average spacing)
Case 2: (40-10)/19=1.58
I hope this is good enough to illustrate why it is IMPOSSIBLE to get wider range and tighter spacing.
What you are saying is that in fact, you can separate 100 miles in 20 intervals that are smaller than the ones you would obtain by separating 50 miles in the same number of intervals.
That makes sense if there were no gear overlap. Could you not get a wider range with tighter gearing simply by having less overlap in gearing? I.E. 53x25 does not pick up right where 39x12 leaves off.
Exactly. And that is really where the advantage of compact cranks comes in. Take the case of a 11/21 cassette. I think that’s as close a spacing as anyone would realistically want. Then a 53 chainring covers ratios from 4.82 to 2.79 (excluding the 21 cog crossover) If you could do it, a 30 inner chainring would pick up with a 2.49 ratio on the 12 cog and go down to a 1.43 ratio on the 21. A 1.43 ratio is equivalent to a 39X27. So if you could make this system work you would get the same range as a 53/39 11/27 with smaller steps between gears and 16 different gears. The downside would be changing 7 cogs when shifting chainrings.
