XLab Torpoedo - valve issue
Without cutting off the valve, is there a way to make water flow throught the XLab Torpedo straw quicker? I have to work really hard to get enought liquid through the bite valve.
thanks
thanks
I just got mine but haven’t had issues. It may be obvious but are you biting the rubber on the valve? You can get fluid to come through the valve without biting it but it is a lot more work. You should be able to pinch it with your teeth just behind the valve head. If so, perhaps you have a defective valve.
