Xlab Torpedo - Question
Hi,
For those of you with the new torpedo (the one with the one way valve), does the valve fit in the same size hole as the straw ?
I have two old style bottles and I am wondering if I can retrofit the valves into the spare straw hole that’s currently blanked off ?
Thanks in advance for any replies / advice.
Cheers,
WD :slight_smile:
Hi,
Cheers,
WD :slight_smile:
I drilled a small hole in the “second straw hole blanking plug” of my old style Torpedo to allow for better fluid flow. It was effective, without causing leaking.
Thank you :slight_smile:
Anyone else tried retrofitting the dolphin valve ?
Cheers,
WD :slight_smile:
